Prius v: Multiple Warning Lights, Hybrid Battery Code, but 12v Disconnect Fixes it. Huh?!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Merv Himself, May 9, 2020.
  1. Merv Himself
    Merv Himself Junior Member
    71
    Georgia, Florida
    2013 Prius v wagon
    UPDATE: Sorry all. Been dealing with a family emergency. I am back with the car now and based on recommendations, I got the Dr. Prius app. The bluetooth scanner is set to arrive today. The app looks like a bit of a learning curve, but I will collect & post as much data as possible.
    If there are any special tests you think I should run, please advise. Thanks again for all your help.
  2. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Thanks, Mendel. Finally returned to the car after a long family nightmare. Got the Dr Prius app you recommended and paired it with a blutooth scanner. I have a tons of data now. Pack Voltage, blade voltage, etc. And a slew of error codes the auto parts store scanner was not able to read: Battery codes as follows: P3000, P3019, B2799, P1234, C7777 Yikes!
  3. ChapmanF
    18,192
    Those aren't all battery codes.
    B2799:
    One of the following conditions is met:
    • Error in communication between power management control ECU
      (HV CPU) and certification ECU assembly (smart key ECU assembly)
      or ID code box (immobiliser code ECU)
    • Error in communication lines
    • Communication ID is different between certification ECU assembly
      (smart key ECU assembly) or ID code box (immobiliser code
      ECU)*2 and power management control ECU (HV CPU) during
      communication
    Caveat: that's from a Gen 3 liftback manual, you might want to double check in a manual for the v.
    I do not find P1234 or C7777 in the liftback manual at all. I don't think the battery ECU gives any C codes.
    I am always hesitant to say that 'off brand' code scanners are displaying those five-character DTCs incorrectly. I mean, that shouldn't be easy to do! The software sends a query, gets two bytes back, decodes them as four hex digits, munges the first one like this:
    and done. It should be really hard for even the cheapest scan tool to be doing that wrong.
    But I end up wondering if there are maybe checksums in the protocol (I knew once, but don't have time to look up again just now), and maybe the cheap implementations are flat-out forgetting to check those and retry messages that came noisy.
    Kind of perplexing. Maybe P1234 and C7777 are real codes on a v.
    jzchen likes this.
  4. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Not sure. Can't find anything that explains those codes.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    I just did a quick scan of all 63 posts in this thread and see no mention of checking the health of the 12 V battery.
    Before you waste any more time or money, you NEED to do that first.
  6. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Thanks, Sam. Good point. The 12V is brand new. The old one was testing pretty good, but it was 3 years old, so when this multiple warning light issue started, I eventually just replaced the 12V as part of a hail Mary pass. We are in florida, so after 3 years on a battery in this heat I figured it was due for a new one anyway.
  7. ChapmanF
    18,192
    Did you look in the repair manual specifically? Too many people say "I couldn't find anything on ..." when all they mean is they haven't looked in the obvious place.
    Now, if they're really not in the Prius v repair manual for your year, that gets back to ... what on earth is Dr. Prius doing when it thinks it's decoding DTCs ... ?
  8. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    I am trying to find a repair manual online, but without success.
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I don't think I could find those codes in my "copy" of the repair manual. I think Toyota relinquishes that "work" to it's Techstream system.
    moto g(7) power ?
  10. Mendel Leisk
    41,448
    I've never found a v Repair Manual (in pdf format) either. I think part of the problem is there was no hard copy version, so a nicely collated pdf has maybe never been compiled officially. Still, someone may have "cobbled" one.
  11. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Just checked the battery. Like I said, it's new but here are the readings:
    After sitting overnight, car off: 12.7V
    Running, Ready Mode, with radio, lights, ac cabin fan on: 14.3V
    In Accessory mode with lights, etc on: 12.1V
  12. Mendel Leisk
    41,448
    That 12.7's with the car off, using a multimeter? That sounds good. The rest don't mean much.
    Merv Himself likes this.
  13. sam spade 2
    7,035
    2,802
    2017 Prius c
    Check.
    The second one means that the charging system is working good.
  14. ChapmanF
    18,192
    Nah, they document the trouble codes very thoroughly in the repair manual. What's built into Techstream is nothing but fortune cookies.
    ... though if your subscription is active, Techstream can link you right to the section in the manual online.
    But this wouldn't be the first time some oddball scantool has reported goofy codes. As I said in #63, I sure don't get it. Decoding four nybbles as hex and looking one up in a table should be pretty hard to mess up. But maybe some scanner software developers just have that talent.
  15. mikefocke
    3,997
    1,807
    Sanford, NC
    Recall that not all codes are public, there may be legal issues once you get beyond engine/emissions.
    For another brand car I'm familiar with (and for which they last published a written repair manual in 1998), the best scan software for owners for that brand is still uncovering codes and their meanings and diagnostic tree flow charts more than 20 years later. Active development took years and years with each release providing another layer of coverage of an area of the vehicle.
    Scan tools intended for use by mechanics can often do more than read codes and give you a few words of description, they can often trigger actions via the car's many computers that help in the diagnosis. And at least one scan tool software package has multiple versions with the unlimited uses on an unlimited number of cars (repair shop version) being priced much higher than the enthusiasts version. It is also more capable. All for an engine whose rebuild can easily run $30k.
  16. ChapmanF
    18,192
    All of that is ... true ... and yet ... does not change the fact that simply displaying a DTC, whether you have heard of it or know what it means or not, is a matter of nothing more than getting a 16-bit number and mapping the two high bits onto (P, C, B, U) and the remaining 14 into hexdigits.
    And yet, somehow, one keeps hearing of people using oddball code readers that somehow end up displaying codes that one never sees from Techstream.
    Techstream has a lot of Toyota-specific knowledge baked into it, but not the kind of knowledge that changes what bits or hexdigits are.
  17. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    UPDATE: Brace yourselves, friends. I took it to a dealer for a scan. Yep. I'm a broken man. I asked for a detailed readout and they handed me an invoice for $168 with ONE code printed on it: P0A80. I told them I'm not paying $168 for a code I already pulled up for free at Autozone and asked them to give me the detailed printout they promised me. Twenty minutes later, I got the printout and will post soon. (Paperwork is in my son's truck right now)
    In the meantime, my friend helped me make a couple videos this morning that show the Dr. Prius readings side-by-side with my in-car actions.
    This one shows tests while parked, in accessory mode, and in ready mode:
    This one is me driving at various speeds, plus Full Battery test:
    Also, this is the high pitched noise she was making last night after the 45 minute drive home:
    God bless anyone who has the patience to watch these and offer some help.
    Funny thing ... the car is now driving as if it has no problems. If I didn't know about the re-occuring warning lights I would never guess there was anything wrong with it. However, the readings on Dr. Prius seem inconsistent, especially as it relates to small resistance changes.And the Full Battery test produced block errors. (but not always)
    Thanks to all once again. -Merv
  18. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
  19. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The highlighted area of Block 7 tells you everything you need to know. That block has a failing/failed module. The other 2 blocks are on the way.
    Take a look at the second photo, third line item. That's 'shortwave highest value". Its a measurement of the HV isolation from the rest of the car. 5 volts is perfect insulation/isolation. Most cars show 4.99V. Yours is showing 4.98V (which is fine), except for 4th column reading, where it's showing 0.03V, which is a dead short circuit between the HV system and the car chassis. Wonder what's up with that.
    #79 TMR-JWAP, May 26, 2020
    Catherine Kourouklis likes this.
  20. jim240
    jim240 Junior Member
    24
    You might be able to clean the monitor contacts, I've never seen a bank at 12V that didn't have the mushy accelerator peddle.
