Prius V not fully starting issue
Discussion in 'Prius v Main Forum' started by Jeremy Lekich, Jan 2, 2021.
  1. Jeremy Lekich
    Jeremy Lekich Junior Member
    Nashville
    2013 Prius v wagon
    Hello y'all,
    We have a 2013 Prius V with 160,000 miles. It has run great since we purchased it a year ago. Recently it has run into an issue where when we press the start button, all the dashboard lights come on (including the stereo and headlights) but the 0 MPH does not show and the car can not be put into reverse or drive. We have to turn the car off and on many times before it starts up normally (sometimes taking many minutes). My best guess is the combination meter, but I wanted to get input from this wise crowd before replacing it.
    Many Thanks
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    What's the voltage on the 12 volt battery?
    Air_Boss likes this.
  3. Jeremy Lekich
    Nashville
    2013 Prius v wagon
    Not sure. Guess I need a voltage meter to get that info?
    Raytheeagle likes this.
  4. Jeremy Lekich
    Nashville
    2013 Prius v wagon
    I was doing more reading and it looks like it could be related to the inverter recall and computer update recall? Just called Toyota dealership to get more info.
  5. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Yup;).
    Start there and see where it takes you:).
    If original and it's been sitting more than usual (COVID-19 caused), it is probably time for a new battery(y).
  6. Jeremy Lekich
    Nashville
    2013 Prius v wagon
    ok thanks so much. And when you say battery, you mean the smaller boot battery, not the hybrid battery?
  7. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Yes, the small12 volt battery ;).
    Good luck and keep us posted(y).
    scona and Air_Boss like this.
  8. Jeremy Lekich
    Nashville
    2013 Prius v wagon
    Thanks! Have an appointment with Toyota Monday to get recalls fixed. Hoping that will do it.
