Prius V not running right after head gasket replacement
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Bofronado, Jul 14, 2026.
  1. Bofronado
    Bofronado Junior Member
    Iowa
    I have a 2014 V that needed a new head gasket. I followed a great video that guided me through most of it, but after putting it back together it wasn't running right. I am getting the following codes: P0301, P0031, P0351, and P3191. I am unable to clear any of these codes with a scanner or disconnecting the battery. I was sure I had the timing chain not on correctly, but I was able to verify that it was right by removing the valve cover and the crank pully. Just a a complete loss as the what is going on. It starts and runs but sounds horrible.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    Often its a vacuum line not connected such as the pcv or evap. Sometimes its a missing or loose gasket on the egr system. Other times its a disconnected sensor like the maf or the first cat air flow sensor. The #1 ignition coil could have a loose connector or bent pins. Its possible more than one of these things are not right.
  3. Dolsenany
    Dolsenany New Member
    Las Vegas
    2014 Prius v wagon
    Following this post. I too changed the head gasket and have some issues. I am getting code P0016 but no engine light. There is a rattling sound that seems to be coming out of the engine top. I have changed both camshaft and crankshaft sensors and redid the timing chain but still have the rattle. I have put over 60 miles and still no engine light but permanent code P0016. Anyone who might know what to do next?
  4. rjparker
    11,104
    6,967
    Texas Hill Country
    Page 2 of attached pdf suggests mechanical timing or ecm. Given the circumstances it points to mechanical timing.
    If the parts cannon introduced aftermarket sensors. I would put the oem parts back in.
    Good step by step
    #4 rjparker, Jul 15, 2026
