Prius V Speedometer Head Cluster
Discussion in 'Prius v Accessories and Modifications' started by bostonbruins8703, Jan 8, 2020.
  1. bostonbruins8703
    bostonbruins8703 Active Member
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    I have a 2013 Prius V. I've been debating about upgrading the headcluster using a headcluster from a 2015 and on. Does anyone have any experience or know if this is possible to do? is it simple as plugging it in or what? I can't seem to locate anything on the forum about it.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,604
    Taylors, SC
    No, 2012 and 2013 are the same. Many wrecking yards say 2014 is the same, but I am skeptical.
    2015 and 2016 are the same. The 2017 is again different, although I am also skeptical, since they have different board part numbers.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    You might find more information by searching for combination meter, Toyota’s term (in service documentation) for what is usually called the instrument cluster. The head unit is for the radio or navigation system.
    In the editions of the Repair Manual (more info) for model years 2013 and 2015, see the Terminals of ECU pages in the Meter/Gauge System section. The shapes of the two connectors (L27 and L125) for the combination meter are the same for both years, but there are a few terminals used only on the later model, for steering pad switches and a local bus connection to the navigation receiver assembly. I don’t know what would happen if those weren’t connected, and of course, there may have been other changes to CAN bus messages, which might keep a newer combination meter from operating properly in an older vehicle.
    Toyota’s parts catalog for the Prius V lists six different part numbers for the combination meter sub-assembly (part name code 83809) for the U.S. market, depending on the production date and characteristics:
    83809-47020 — 2011-09 to 2013-07
    83809-47021 — 2013-08 to 2014-11
    83809-47120 — 2014-11 to 2016-05
    83809-47230 — 2014-11 to 2016-05, US GRADE2&STEERING SWITCH-WITH(W/AIR CONDITIONER CONTROL SWITCH)
    83809-47121 — 2016-05 to 2017-11
    83809-47231 — 2016-05 to 2017-11, US GRADE2&STEERING SWITCH-WITH(W/AIR CONDITIONER CONTROL SWITCH)
  4. bostonbruins8703
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    thanks for the info everyone!
    Elektroingenieur likes this.
  5. dy/dx
    dy/dx Junior Member
    26
    United States
    Did you install the 2015 combination meter?
