Prius v Two will not start
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Mason5882, Jun 13, 2021.
  1. Mason5882
    Mason5882 Junior Member
    Prius v wagon Two. 2012 with ~ 125,000 miles. Over the last day or so the FOB didn't unlock doors consistently and then today I was unable to start my car. My trouble-shooting steps + results:
    - I tried both FOB's and 3-4 batteries that all seemed to be OK when measuring with multimeter.
    - My 12V battery is 3.5 years old, but seemed OK with multimeter.
    - I was able to start my car by holding the Toyota emblem on the FOB up to the start button.
    I've saw this thread 2012 prius v three not starting newer battery says full | PriusChat. I am not familiar with IPM. Could I be experiencing something similar or am I missing something obvious? Thank you!
  2. Air_Boss
    Air_Boss Senior Member
    4,238
    1,192
    New Yawk
    Have any relevant inverter motor generator TSBs been accomplished?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    What exactly does "seems OK" mean ?
    Do you have a battery charger ??
    52,695
    fob battery should be 3.3 volts. do you have two fobs?
    12v should be at least 12.4 at rest, and not go below 12 volts after the headlights have been on for 5 minutes.
    test at the jump point under the hood. the age of batteries is mostly irrelevant
  5. Mason5882
    Thank you for the response, Air_Boss. I haven't done anything beyond what I listed in my original quote and "relevant inverter motor generator TSBs" are potentially further than my mechanical knowledge + skill set. I'll look that up to better determine if that is correct or not, but any elaboration would be appreciated.
  6. bisco
    52,695
    i don't see a relationship to the inverter if the car starts by holding the fob to the power button, someone please correct me
  7. Mason5882
    Sorry for lack of clarity. I measured it at rest and it was in excess of 12V. I do not have a battery charger.
    FOB's: Good on the batteries and I do have 2 FOB's. Tried both with multiple batteries.
    I measured the 12+V (analog) at the battery itself and not at the jump point under the hood. I did not measure it after the headlights had been on for 5-minutes. I can try this and confirm more precisely.
    Thank you both for your responses + help.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    "in excess of 12 V" is not a good enough measurement.
    At 12.0 volts, it is about half discharged.
    The first thing you need to do is take the battery out and get it tested.....and check the main connections.
    Or borrow a battery charger from someone.
    Based on about a million stories similar to yours, the odds are great that your battery is weak and needs to be replaced.
  9. Mason5882
    Thanks sam spade 2. I hope you are correct will pursue that route first.
  10. Mendel Leisk
    42,196
    I'd peg 12.0 as in bad shape. A volt meter gives some idea, but I would confirm with an electronic load tester*. They require input as to vehicle's battery type, and rated cold cranking amps. They do a test, report voltage AND as-tested CCA, then give a verdict, say "pass", "pass but recharge and test again", or "fail".
    * Dealerships have these, but will likely charge, anywhere between $50~100. Automotive retailers, especially those selling batteries, have such testers as well, and will usual test for free. You can also purchase prosumer level tester of this ilk (Solar BA9 is one example).
  11. Air_Boss
    4,238
    1,192
    New Yawk
    If the IMG TSB has not been done, it is a ticking clock. The car is due for the IMG TSB at the dealer.
  12. Mendel Leisk
    42,196
    What’s that, inverter related?
  13. Air_Boss
    4,238
    1,192
    New Yawk
    Yes, Inverter Motor Generator IMG
  14. Mason5882
    UPDATE -
    Thank you to everyone for your feedback. In appreciation I wanted to report back on how things ended up going yesterday:
    - Went to Autozone and they tested out the 12V with their electronic load tester. Things tested out fine.
    - Car acting worse to the point where the manual key would no longer trigger the door locks.
    - I took the car to the dealer and they put a new battery in the FOB and they say (I haven't seen it yet) things now work fine.
    I am a bit confused because I tried both FOB's. I used 5 different batteries, 3 of which were new. I confirmed all of the batteries were at least 3.3V (albeit with my analog multimeter). The new batteries were Panasonic. The dealer said it may not matter what the voltage measurement is as some brands of batteries just do not play nice with the Toyota FOBs. I haven't heard of this before, but I hopefully do have a functional car again.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Total BS.
    Your ordeal might not be over yet.
    YLeaf and Tim Jones like this.
  16. rjparker
    rjparker Tu Humilde Sirviente
    10,887
    6,833
    Texas Hill Country
    Just like the 12v battery, the real test for any battery is under load. Obviously a coin battery is hard to measure in its working environment. To me the bottom line is their new coin battery works. I can't believe they would have done anything further and not charge you.
  17. ChapmanF
    18,894
    A couple of the parts in there are known as the IPM (intelligent power module) and the MG ECU (which sits right above it). "IMG" is probably what you get if you kind of run those two part names together, but it might tend to flummox people who try to look up the bulletin, as "IMG" isn't really what Toyota calls anything in there, as far as I know.
    Air_Boss likes this.
  18. Air_Boss
    4,238
    1,192
    New Yawk
    Right, it is incipient or actual failures to components on those two boards that control IMG function that are at issue, which require either hardware replacement, and if not yet failed the firmware update.
  19. ChapmanF
    18,894
    Again, IMG is kind of a non-Toyota term; people can find the relevant literature more easily if we stick to things like inverter, IPM, and MG ECU, which are the names that will show up in the bulletins and service campaigns.
  20. Air_Boss
    4,238
    1,192
    New Yawk
    Form over function, whatever.
