Prius v wagon hybrid light
Discussion in 'Prius v Main Forum' started by Apatel1101, Sep 12, 2022.
  1. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Anyone know what could be wrong? This is the only light that popped up
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    Several things, some worse than others. Need to read codes.
    Air_Boss likes this.
    49,492
    how many miles on her?
    you can start with the 12v, then inverter fluid movement, then clean the cooling fan and intake, then the codes, or just get the codes read
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    The light is gone. Idk how but it was raining heavy here when it came. The next day when i tried to get the codes, there was no codes.
  5. bisco
    49,492
    must be moisture getting into a connection
  6. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    P3107-214 but light is gone so idk what to do?
  7. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Did the ECU, BCM, or related connectors get wet?
  8. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    How many miles?
  9. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    No clue but ut was raining heavy.
    Where are the module located so i can check for any corrosion
  10. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    No clue but it was raining heavy.
  11. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
  12. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
  13. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Is there a echo in here?
  14. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
  15. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
  16. ChapmanF
    15,617
    When you start seeing duplicated posts, it is easy to go check whether somebody has bumped this thread lately:
    this website has gone ballistic. | Page 104 | PriusChat
    Whenever the server is acting up like that, a lot of people get timeout errors when they try to post, and they aren't sure the post made it, and they try again (and sometimes again, and again, and again).
    When you see a bunch of duplicate posts like that, it isn't necessary to add a bunch more duplicate posts like that. :)
  17. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Can you repeat that?
