Prius V wheels and tires
Discussion in 'Gen 3 Prius Accessories and Modifications' started by anonymoususer, Jun 30, 2010.
  1. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Only if you don't like the potential of being more efficient... hahaha. :) In all seriousness, they should help with increasing you mileage returns but....
    I think Cossie put it best: it's about your driving style. You could have the lightest rim/tire setup, but if you floor the accelerator in PWR mode all the time, you're probably not making the most efficient use of the lighter setup. The ligther wheels will assist with efficiency, but they definitely will not help if your driving style is aggressive.
  2. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    It doesn't hurt to shave weight from car, but the true benefit is minimal unless you are doing something crazy. As a daily driver, does it really matter? Even if you do get the 2mpg difference, the 2mpg @ $3/gallon over 50K miles is less than $120 bucks. If you can afford to buy new wheels and tires, I am sure you are not going to cry over $120 over 5 years. It's like calling people stupid for buying options, but then certain things are worth certain values to some people.
  3. HI MPG
    789
    133
    93
    Orange County, CA
  4. anonymoususer
    anonymoususer New Member
    63
    honolulu
  5. EmuMessenger
    EmuMessenger New Member
    35
    Collierville, TN
    I am really surprised to read they are not lightweight. Do we have confirmation of the 25ish lb estimates?
  6. yadax3
    yadax3 Member
    237
    22
    Northern Nevada
    When I had my wheels changed out the guy at my dealership remarked about how stock wheels are notoriously weighty.
  7. Thai
    Thai Prius Neophyte
    1,197
    89
    x2 on the confirmation...Has anyone else confirm how much the OEM 17" rims weigh?
  8. HI MPG
    789
    133
    93
    Orange County, CA
    I can tell you this... I was shipped some stock OEM 17s. The total weight of one of the boxes from the shipment was 29.1 lbs. The rim is a fairly tight fit in the cardboard box, so I would say the box is no more than 20in x 20in x 10in. Having said that, I would highly doubt the box weighs that much more than 5 lbs, if even that. Not at all that scientific, but I guess I could weigh the box to figure out the weight of the rim.
  9. VolkCelicaGTS
    VolkCelicaGTS New Member
    South Bay, SoCal (310)
    Redacted for ignorance. Sorry! :D
    - Dan
