Prius vibration problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pavel Volkov, Mar 14, 2013.
  1. Mendel Leisk
    42,293
    #9 is very strange.
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Due to the sheer number of members on this forum, it is obvious that the Prius does not have a flaw that would cause this vibration or we would be aware of it. The vehicle is in its sixth and final year of production, so we have a lot of owners who would have made this obvious before now. The only thing it could be is a bad batch of tires...
  3. Mendel Leisk
    42,293
    ^ It could be a bad batch of wheel bearings. And if the dealership got cars with consequitive serial numbers....
  4. irrational
    irrational Member
    102
    38
    Tulsa, OK
    Not that I'd take the time to do this on a rental, but... if he gets the front of the car up on jack stands diagnosing a bad wheel bearing is pretty easy. Just check for lateral play and/or grinding/clunking sides.
    I'm assuming the car didn't have these symptoms originally. Something occurred on #2 or between 2&3 that lead to this.
    It's hard to tell from the description if the vibrations vary by speed and/or are present throughout all speeds. The description mention he thought the tires needed balanced, so that would lead me to believe that the vibrations only occur at certain speeds?
  5. Colleen01
    Colleen01 New Member
    2014 Prius v wagon
    Gerald,
    What happened at your arbitration? I have the exact same issue. I had arbitration with the NcDS last month and they felt the vibration while I drove but denied the claim saying it was normal for that speed. I have requested a hearing with the state now.
  6. Colleen01
    2014 Prius v wagon
    Hi Boris,
    Same issue here with mine. Have you gotten it resolved? I am going to arbitration with the state soon.
  7. bisco
    52,803
    hard to believe no one has found resolution for this.
  8. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    Take your Prius to the dealer and let them check the Manifold for any sod and dirt that could block the small intake holes. I experienced that before as you describe, then i found out it was the manifold which caused this problem i had.
  9. Eclipse1701d
    645
    224
    Three Touring
    Does it feel like it comes from the rear axle? Mine had a vibration that I solved with the trd anti-sway bar...
  10. Okinawa
    Okinawa Senior Member
    1,333
    320
    Maybe this would be a lemon law issue.
  11. GregP507
    GregP507 Senior Member
    3,002
    481
    Sounds like tire harmonics. Try to get them balanced properly. Also check your wheel bearings.
  12. rolawson
    rolawson New Member
    Kentucky
    I am having the same issues with my 2012 Prius C. I bought the vehicle off of an older couple that drove the vehicle around town. It has 22,000 miles on it. Toyota dealer balanced the tires and said that their tech said that this was just the nature of the car. This is crap. What process do I need to take next? Why are the people that had hearings in regards to this not posting their results?
  13. chuckwagon
    chuckwagon Junior Member
    I now have 90,000 miles on my 09, and the third set of tired ( Ecopias). I am convinced the problem is a drive train balance problem. I have learned to live with it.
  14. bisco
    52,803
    i wonder how many people never drive over 65 mph.
  15. rolawson
    rolawson New Member
    Kentucky
    My car has the problem at all speeds. It is most noticeable at speeds over 40mph. The vibration is worse at times. The worst is coasting or at just enough gas pedal to maintain a speed. This is not acceptable. I will take this to the courts. Again, why are we not hearing from those that filed complaints, where they bought out?
  16. bisco
    52,803
    why do people come here for advice, and then not return to help others? selfish.
  17. Okinawa
    1,333
    320
    I do not have a c. I have had cars that I have had vibration problems and other problems that turned out to be tires. I would replace the tires with a new set of Michelin tires just to rule the tire problem out.
  18. bisco
    52,803
    the trouble with balancing and alignment is, it doesn't solve a tyre defect.
    Okinawa likes this.
  19. rolawson
    rolawson New Member
    Kentucky
    Had tires balanced and road tested by Toyota service department. Not the tires. They called their Toyota rep and was told this was normal for the car. This is not normal.
  20. bisco
    52,803
    can you drive another with the service manager to compare?
