Prius vibration problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pavel Volkov, Mar 14, 2013.
  1. Pinoyrious
    Pinoyrious Junior Member
    16
    24
    Highland
    Any updates about the vibration issue? Mine is doing the same thing and I thought it was out of balance tires. I had them road forced balanced but my car still have the vibrations. Installed winter wheels and tires which were road force balanced by Tirerack and still have the vibrations.
    52,858
    maybe there's a heavy spot on one of your wheels. have them calibrate the machine first.
    i wonder what happened to @rolawson law suit?
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I may have said this earlier in the post, but I will say it again. My vehicle vibrated, at certain speeds, and it came from the rear of the vehicle. I installed the TRD anti-sway bar, and the vibration has never returned. Not to mention the improved handling ability.
    SnT08Prius likes this.
  4. Mendel Leisk
    42,351
    That's not good. And two sets of tires/rims eliminates them. Unless you've got really bad luck, lol.
  5. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Check your tires for scalloping, had the same when my struts needed replacing. The helpfull people at Les Schwabe let me know $$$
    Also check your drive axels $$$$
    iPhone ?
  6. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    He was talking about the weight of the tires, not the tire pressures.
  7. ricardo b
    ricardo b New Member
    manitowoc
    same exact problem even with new tires
  8. Wildelrosar
    Wildelrosar Junior Member
    Ramsey,NJ
    Hi. What’s the update? Is it post #80 bad wheels and/or tires?
    Just oicked up a 13 Persona that’s doing the same vibrating at certain speeds sometimes none but it’s annoying enough. Switched tires and sane issue
    I’m about to get it roadforce balanced to determine if wheels and/or tires are the culprit.
    My prior 08 with 285k miles didn’t have this issue.
    Thanks!
  9. Paul Schenck
    524
    307
    Fresno, California
    I had a problem for a time with the CV joint. I found out when I reached up from underneath and found the right one(passenger) had worn to where it caused a vibration at speed.
    iPhone ?
