Prius Warm-up Stages and Efficient Driving
Discussion in 'Gen 3 Prius Fuel Economy' started by XavierKing, Apr 15, 2015.
  1. XavierKing
    XavierKing Junior Member
    Raleigh, NC
    Greetings!
    I have been studying the art of Pulse and Glide recently. I think I now have P&G down, but I'm not quite sure how to drive the car when it is still in the warm-up stages when the engine is cooler than 157 degrees.
    I don't know everything about the warm-up stages, but I know that the engine doesn't like to turn off when the car is still warming up to 157. Please correct me if any of this is wrong or feel free to contribute additional info.
    My question is this: How should I be driving during the initial warm-up stages? I don't want to allow the warm-up to take my average mpg down too much.. How should I drive while it's warming up?
    Thanks.
  2. ITgem679
    ITgem679 Junior Member
    73
    17
    Wow. Ok, apparently I have a lot to learn. What is this P&G you speak of? I had not heard of any way to "drive my Prius"...
  3. XavierKing
    Raleigh, NC
    I just shortened Pulse and Glide to P&G. Are you not familiar with the pulse and glide technique? It is fairly commonly discussed around here to get better mileage. The idea is this: you "pulse" up to a certain speed (low mpg during pulse), and then when you reach your desired speed, you "glide". You glide by taking your foot off the accelerator and only apply just enough pressure to have nothing display on the HSI indicator screen or apply slightly more pressure to fill in just a very small section of the left side of the display. During the "glide" phase, you get much higher mpg (unlimited mpg if the gas engine is off). The bad mpg during the pulse averages out with the unlimited mpg during the glide to result in some pretty good mpg. I'm still working on perfecting the art. My mpg readout currently averages 60. Trying for a little better, but pulse and glide doesn't work so well when the car hasn't warmed up enough to allow the engine to shut off.
  4. bwilson4web
    16,512
    The "search" function will quickly find many threads with more technical details.
    I would suggest looking at ScanGauge II or Android+Torque to get live, detailed, driving metrics. Then you'll be able to map engine coolant temperature versus engine operation and adjust driving style to current conditions.
  5. frodoz737
    frodoz737 Top Wrench
    4,791
    2,559
    33
    At start up, allowing the engine to do it's first on off cycle before driving actually improves your overall mpg and emissions output (warms up the catalytic converter). After that it's up to you to find "your" sweet spot by means suggested or that of your choosing.
    MiniSimp likes this.
  6. Mendel Leisk
    42,266
    I set the displays to show the Hybrid System Indicator, and pretty much anytime accelerating, try to keep it in this zone:
    I don't always succeed, for various reasons, like grade, impatient traffic, etcetera, but I try.
  7. Tideland Prius
    16,670
    Gen3 warming up stages | PriusChat
    As stated in the thread, drive gently in S1a to minimise battery drain (unless you're already at 7 bars from the previous trip or you had to idle and the engine charged the battery up to 7 bars while idling). I usually use this time to crawl along a side road, alley or residential road before making it out to the main road.
  8. Tideland Prius
    16,670
  9. XavierKing
    Raleigh, NC
    Thanks, Bob! You know, I do already have a scangauge and I have been trying to pulse within 1200-1800 rpm as stated in a different post. I did want to get your opinion of using this RPM range for pulsing.
    Thanks, Tideland! That was actually the page where I learned about the stages. It turns out I did not read that page thoroughly enough!
  10. bwilson4web
    16,512
    I use a different driving strategy:
    • Only when engine too cold to go off, below 40C engine coolant temperature - I will take the neighborhood route, 25 mph, and shift into "N" when the car can coast.
    • All other times, I drive +95% on cruise control - speeds above 23 mph and above 40-52C engine temperature.
    • Highest efficient-power rpm - 3,200 rpm, this is the highest EGR % power point and typically seen climbing steeper grades.
    • Above 3,200 rpm - only used as needed for rare, exceptional conditions like . . . sitting at a light with a noisy motorcycle to left, 3-lanes become 2 within 1/4 mile, and in the lane that ends. Shift into "N" to keep engine OFF; floor accelerator; light turns green, and; shift into "D" . . .
    #10 bwilson4web, Apr 17, 2015
  11. XavierKing
    Raleigh, NC
    Thank you for the strategies, Bob. May I ask what your current average mpg is?
    Thank you and have a great day.
  12. bwilson4web
    16,512
    Year round, I'm running 52 MPG with both the 2003 and 2010 Prius. The 2010 Prius does it about 5 mph faster and better in cool weather. For my daily commuter, I'm still using the 2003 primarily because it ain't broke, performs well enough, and is a lot smaller for parking and handling.
  13. Mendel Leisk
    42,266
    Bob, in post #10: "40C" should read "40F"? (purely editorial)
  14. XavierKing
    Raleigh, NC
    Thanks Bob! I understand that you've been involved with the community for quite some time. Thank you for your input.
  15. XavierKing
    Raleigh, NC
    Hey Bob! I hope you're available for one more question. I was reading in the 600 mile club about people who just set the cruise control for 57 or so. My commute involves a 20 mile stretch in a 65 mph zone. You know, I'm actually averaging a HSI readout of 56 mpg right now. Do you think I could benefit from cruise control? And do you have any input regarding cruise control speeds? We have a lot of hills around here..
  16. Mendel Leisk
    42,266
    ^ Try it.
    bwilson4web likes this.
  17. bwilson4web
    16,512
    We learned our techniques by experimentation. I have no idea about your route and types of hills. My general rule:
    • follow (DO NOT TAILGATE) the slowest traffic - this lets you appear "stuck" as opposed to being the rolling road-block. Following traffic will pass without giving the Prius a second thought.
    • cruise control is my favorite technique:
      • pat stalk up - increases speed 1 mph for each pat, up to three stacked
      • pat stalk down - decreases speed 1 mph for pat, up to three stacked
      • just trim the cruise control to follow easy
  18. XavierKing
    Raleigh, NC
    Thank you so much, Bob. This all makes a lot of sense. Thank you for taking the time to offer some advice today. I have s few more tricks to try out now!
  19. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    I agree with Tideland about S1a; I back out of my driveway, then drive to the stop sign at the end of my road at slightly-higher-than-idle, and then continue at that speed to a stoplight that's maybe 100 feet from the stop sign. By that point, I'm usually out of S1a. The road there has a speed limit of 45, so I'll then just go to DWL - keeping the HSI right at the halfway point is quite efficient, and the car warms up fairly quickly because the engine is always on.
    Of course, I don't always take that particular road, and sometimes I start from somewhere that's not home (obviously)... In that case, I try to anticipate when the car might be more willing to shut off the engine (it has a VERY strong desire to turn it off at 40°C and again at 68°C, assuming you end S1a below 40°C). I plan a pulse so that it peaks right when the coolant gets to that temperature, and then glide for as long as I can. When the car is still warming up, I'm a little more willing to use the electric-only side of the HSI if I just need a little extra power to make it to the next place where I need to slow or stop - once the car is warmed up, I'll avoid using any electric power. By using electric power that way, I can avoid having the engine running as I'm slowing or stopping, if it had already stopped while I was moving.
    My average has been climbing up to about 54 mpg recently, but I'm definitely held back by traffic (and my wife using the car; she puts probably at least 5 times more miles on than I do these days). Last week, I had a particularly enjoyable 25-mile round trip (with 2.5 hours of cooling in the middle) where I got about 78 mpg - partly through good luck with traffic as rush hour was ending, and then partly through a lack of traffic on the way home late at night.
    Anyway, try lots of things, and do what works well for you. There's no one "right" way to maximize your efficiency, I think there are just too many variables.
    Agent J likes this.
