Prius warning light. Will not start.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Donnygeewebb, Aug 16, 2017.
  1. Donnygeewebb
    Donnygeewebb New Member
    26
    Georgia
    Hello all. Newbie here. To start off, I bought this Prius about a year ago needing a new HV battery. It had been in a wreck, replaced the front bumper and painted it. Got the new battery in and everything was fine. I went out of town for work for about six months came back and drove it and everything was working OK. Two days ago I was driving home and the triangle of death warning light came on along with a check engine light. Soon after a fall at the brake light VCX light (I'm assuming, (but really I've been drinking)) along with the ABS light and the (!) Light. I replaced the 12 V battery and drove it home from O'Reilly's and about halfway down the road these lights come back on along with a solid warning sound. The AC quit working and I can hear a fan constantly running in the back even after I turn off the AC. After reading a couple of post on this forum, I checked the HV battery to see what caused the triangle of death light. All of the battery cells in the HV battery test to be 7.8 V. After cleaning the copper connectors on both buses(they were pretty corroded), I get everything plugged it back in and back together and now my Prius will not start. I have an off day tomorrow and I plan on using it to troubleshoot what the problem may be. Any help is appreciated. I'm desperate!
  2. Donnygeewebb
    26
    Georgia
    Well I say new battery, it is new to me but it was used.
  3. Donnygeewebb
    26
    Georgia
    I will also add then after putting my scan tool on it, the original check engine light code was for a coolant flow control valve, but after it would not start a new code came up for battery voltage being too high Or too low. I checked the onboard diagnostics and the HV battery looks OK and the 12 V battery is new.
    52,904
    welcome!
    you probably didn't complete the sequence on the orange safety connector.
    Raytheeagle likes this.
  5. Donnygeewebb
    26
    Georgia
    I double checked every plug in and everything is in it's correct position
  6. Donnygeewebb
    26
    Georgia
    Also thank you so much for your quick response
  7. bisco
    52,904
    did you slide it up, after pressing it down?
  8. Donnygeewebb
    26
    Georgia
    You're talking about the big orange safety plug correct? Isn't it supposed to slide down? I even jiggled it back and forth to make sure the connection was certain.
  9. bisco
    52,904
    there's a sequence that many people struggle with. i would suggest a youtube search, just to be on the safe side. it may be something else entirely.
    and don't trust a new 12v, check the voltage and connections, especially negative to body.
  10. Donnygeewebb
    26
    Georgia
    The onboard diagnostics shows the 12 V battery actually being 13 V or something close to it I can't remember. I am about to YouTube the connection sequence now.
  11. Osxarsam17
    Osxarsam17 New Member
    US
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    13v is good.
    When the A/C suddenly stops working, that usually points to an inverter failure; usually due to the inverter coolant pump failing to pump coolant. Easy check: with car on and in ready mode, look in inverter coolant tank for turbulence.
    Loud fan in the back typically means a HV battery failure; most likely from sitting for six months.
    Double-triple check the orange safety plug.
  13. Donnygeewebb
    26
    Georgia
    @fotomoto would that be caused by the coolant control valve? That's what the original code was for anyway. The safety plug is definitely in and making contact. As stated earlier all cells read 7.8 v or more.
  14. Donnygeewebb
    26
    Georgia
    @Osxarsam17
    I will check that tomorrow morning as I am not around it at the time. I had to drive my turd Pontiac grand am home this evening.
  15. Donnygeewebb
    26
    Georgia
    Watching several videos tells me that the HV battery was plugged in with the correct sequence. Further help is well appreciated!!
  16. Donnygeewebb
    26
    Georgia
  17. fotomoto
    5,639
    3,815
    So. Texas
    Did u check the pump?
  18. bisco
    52,904
    proxy the new (rebuilt) battery. the cells need to be tested under load.
  19. Donnygeewebb
    26
    Georgia
    @fotomoto can it be done without going into ready mode?
    @bisco how can you test under load? I'm probably asking some dumb questions but this car is like learning a foreign language to me lol
  20. Donnygeewebb
    26
    Georgia
    The code I'm receiving is C1241 "low battery positive voltage or abnormally high battery positive voltage"
