Prius warning light. Will not start.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Donnygeewebb, Aug 16, 2017.
  1. bisco
    52,904
    you either need mini vci (amazon $25.) and a compatible laptop, or you can take the battery apart and test them with a light bulb. (see battery rebuilding threads here)
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    OK, sounds like you have issues with the rebuilt pack. You may need to double check your work/connections or it could have had a hard fail.
    What exactly did you mean by "won't start"? No power whatsoever (no dome lights, dash dark, etc) or the car just won't get into ready mode?
  3. Donnygeewebb
    Donnygeewebb New Member
    26
    Georgia
    Whew! I found the problem! (Sort of). [​IMG] This little guy was tucked under a metal bracket and was hiding from me. It plugs into the orange safety plug. Now, the bad news, the car FINALLY got into READY mode and I drove it around to test it out. About a mile down the road the big triangle light, check engine, ABS and VSC light come on. :mad: I put the scan tool on it and now I have 3 codes. P0A93, P1116, and P1121.
  4. Donnygeewebb
    26
    Georgia
    I also have loss of A/C now
  5. Donnygeewebb
    26
    Georgia
    Did the reservoir check and I'm seeing no turbulence, so I know that needs to be replaced. Would this be causing the other lights?
  6. fotomoto
    5,639
    3,815
    So. Texas
    Possible for phantom codes to be thrown when major things go bad. Yes your pump is done. It's a relatively easy job for the DIY type. Tackle that first.
    Be prepared for possible battery issues once you can drive the car for longer times/distances.
  7. Donnygeewebb
    26
    Georgia
  8. fotomoto
    5,639
    3,815
    So. Texas
    Yup. Sitting 6 months plus through the hot months is very tough on an old battery. BTDT Just don't be surprised if it starts giving you issues once you get the car running again.
  9. Donnygeewebb
    26
    Georgia
    @fotomoto let's hope for the best! I will post if the pump replacement fixes the lights
  10. Donnygeewebb
    26
    Georgia
    Update: all warning lights disappeared after replacing the water pump located behind/underneath the driver side headlight. Wasn't really planning on spending the $160 for the pump and coolant today, but so relieved the car is running fine now. Thanks to everyone for the help!
    Raytheeagle, bisco and fotomoto like this.
  11. Donnygeewebb
    26
    Georgia
    Triangle of death just popped up. *face palm*
  12. fotomoto
    5,639
    3,815
    So. Texas
    I was afraid of that. Well, read the code(s).
  13. Donnygeewebb
    26
    Georgia
    Will do tomorrow when I get back to my shop. I had a check engine light that I ran a scan for and it threw a code for the coolant flow control valve. Causing the triangle of death? No parts warehouse around me can get one and I'm assuming it's because Toyota issued a TSB on it? Guess I'll be heading to the dealer tomorrow. My wallet is crying
  14. Donnygeewebb
    26
    Georgia
  15. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    Presuming the P1121 came back up and yes this is the cause of the Master Caution light.
    Coolant Flow Control Valve is a commonly available part, have you try online Toyota dealers? Should be available overnight and if you use an out of state dealer you can save on sales tax.
  16. Donnygeewebb
    26
    Georgia
    I like the way you think @dolj
