Prius waterpump is making a squealing/screeching noise after driving (video)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zoeboi954, Nov 8, 2016.
  1. zoeboi954
    zoeboi954 Junior Member
    77
    22
    I just been through hell with replaing waterpumps on my old engine before it was replace now I got a my engine swapped out, the waterpump that came with the new engine also failed a couple months ago and it made the same noise , now the new waterpump also makes this squealing noise after I drive. does anybody know why
    Here video, it's a high pitch squeal and a faint squeal. dont confuse the faint squeal as background noise
  2. JC91006
    16,482
    8,400
    Maybe it's the pulley or the belt making noises. Is the belt tension correct?
    If the water pump is not new, just get a new one
  3. ChapmanF
    15,662
    What belt? Profile says the car's a 2010. And the electric water pump is a bit salty to just keep replacing. Strange....
    -Chap
  4. zoeboi954
    77
    22
    No belt, yes 2010 3rd Gen electric water pump. and yes it's a brand new waterpump only been in for about 2-3 months.
    Also new radiator, thermostat, and coolant had been deeply flushed
    And the video was recorded with the vehicle off
  5. zoeboi954
    77
    22
    Just thought I give an update on this. It turns out the waterpump was not making this noise it was my a/c compressor. And it would happen everytime I use the a/c. I'm not sure if that means it gonna fail soon or what. But it still works for the time being
  6. mjoo
    mjoo Senior Member
    1,127
    1,317
    Michigan
    If you don't have a mechanic's stethoscope - a good alternative is to get some cheap plastic tubing. Put one end by your ear drum and the other end near the moving part to isolate the sound.
    Dyjital likes this.
