Prius Wheel Offset
Discussion in 'Gen 2 Prius Accessories & Modifications' started by fledersau, Mar 22, 2021.
  1. fledersau
    fledersau Junior Member
    montreal, canada
    Hi there,
    I bought some used rims for my (new to me) 2008 touring to fit with the 16inch 195 tires i have. The seller told me they're compatible with the prius, and width (7inch) as well as bolt circle (5x100) seem to fit, but i'm a little concerned about the offset. The rim has a 54mm offset, does anybody have experience with such a big positive offset? Do you think it will work?
    Thanks in advance!
  2. Sanchan
    Sanchan Junior Member
    48
    35
    Lake Forest, Ca
    I think it works...I have seen guys using 10-15mm spacer with OEM "Touring" 17 inch wheels. Granted, they are Gen 3 but it shoud be the same for Gen 2. Post pics when you are done! They should look mighty good!
    #2 Sanchan, Mar 24, 2021
