Prius Whole house Converdant Inverter
Discussion in 'Gen 4 Prius Main Forum' started by Chuck Reiss, Apr 28, 2017.
  1. Elektroingenieur
    2,515
    3,287
    Three Touring
    The Japanese version of the Repair Manual (RM3220J) gives a little more information about Toyota’s 1500-watt inverter. The Hybrid Vehicle ECU can definitely intervene and turn it off when necessary. In the section シガレットライタ/アクセサリーソケット(内装) アクセサリーソケットシステム(非常時給電システムあり 注意事項, Toyota explains (roughly translated):
    In the accessory socket system, even if there is no abnormality in the hybrid control system, under the following conditions, the fail-safe function of the hybrid control system activates, the operation disable signal is input from the hybrid vehicle control computer, and the operation is stopped.
    • When the hybrid battery capacity decreases
    • When the hybrid battery is at low or high temperature
    • When the hybrid battery voltage drops
    For my part, I would be very hesitant to connect an inverter directly to the HV battery without a similar protective feature. Barging uninvited into the hybrid vehicle and battery ECUs’ feedback control loops—drawing current from the HV battery that they can’t measure or control—also strikes me as ill-advised, at least without far more analysis than can be done with information from the open literature.
    RCO and alanclarkeau like this.
  2. Haraald
    Haraald New Member
    25
    23
    Seattle
    Converdant just went out of business... anyone have any links to updated info on which inverter to buy for Toyota hybrids?
    52,433
    that's a shame, i don't think there is anyone else. another prius aftermarket company bites the dust.
    well, i'm not surprised, i think only one member here bought one.
  4. Haraald
    Haraald New Member
    25
    23
    Seattle
    Well I've read there's nothing special about Converdant's inverters right? I can just buy any pure sine inverter and have the fuse set at 1kw and it's the same effect? I just want to hook up to the 12v in the back of the vehicle
  5. bisco
    52,433
    oh sure. conversant just had big one that ran off the hybrid battery.
    there are plenty of threads here on small ones running off the 12v.
    Haraald likes this.
  6. Haraald
    Haraald New Member
    25
    23
    Seattle
    ^Thanks, do you have a link to a good thread? I used the search function and I just get threads on the automotive inverter :/
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    If you're referring to a 12V battery - it's under the bonnet (hood), not in the back of the Gen 4.
    Or are you putting in an auxiliary 12v battery in the back like we used to when camping?
  8. IrlSmith
    IrlSmith Junior Member
    Massachusetts
    I have a 3 kW inverter from Converdant connected to my house via a transfer panel installed by a professional electrician. It works well. I can supply more info but unfortunately Converdant went out of business a few years ago so itps probably irrelevant. I don't know of any source for an inverter setup suitable for running off of the traction battery so one could use the high-power main electrical system, not just the 12V accessory circuitry (which is limited to something like 1200 W, I believe).
  9. IrlSmith
    Massachusetts
    What is "special" about the Converdant inverters (no longer being sold AFAIK, alas) is that they are designed to run off the 200+ V main battery, so their power capabilities (3 kW and more) will actually run the key functions of a house.
  10. bisco
    52,433
    unfortunately, this necro thread died a quick death
    knockknock_2 likes this.
  11. kentmitch
    kentmitch Junior Member
    38
    16
    Kansas
    I have one new, unused, for sale. Will post in private sales.
    Mambo Dave, cooljoe and knockknock_2 like this.
  12. cooljoe
    cooljoe Junior Member
    nj
    did you ever sell it?
  13. CaptPete43
    CaptPete43 Junior Member
    Mass, USA
    I used a Converdant inverter successfully for 2 years through multiple blackouts. Using a Prius and an inverter is super quiet and efficient compared to a generator. Since we sold the Prius, our inverter is surplus.
  14. ChapmanF
    18,610
    Does that mean it could be available to PriusChatters? Which size is it?
    krmcg likes this.
  15. cooljoe
    nj
    Just saw your response. Can you PM me and let me know more details about it?
  16. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Apparently, Converdant is now back in business as new company PlugOut Power and have version 4 models 3kw and 5kw inverters for sale. The owner Randy Bryan is taking advanced reservation order now.
    PlugOut Power
  17. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    The 'resources and news' at the bottom of the page only references articles from 2013 to 2015.
  18. Salamander_King
    11,024
    8,970
    New England
    Yeah, there is not much substance to the HP, mostly link to the blogs to older Converdant inverter users. I gathered that the company is very small one owner/employee out of his garage operation. The best way to get more information is to directly e-mail. He does respond.
    #38 Salamander_King, Sep 29, 2020
    Mambo Dave likes this.
  19. KostyaSha
    KostyaSha Junior Member
    Belarus
    Sorry, where is possible to get it to read more details?
  20. Salamander_King
    11,024
    8,970
    New England
    I think you will need paid subscription at Toyota tech site. But from what @Elektroingenieur described, it is written in Japanese (no English translation version). I maybe wrong, but that's what I think.
