Prius with 193K miles and repeatedly dying 12V: repair or donate?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KEF, Jul 14, 2015.
  1. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Thanks. I didn't know if checking the under-hood jump point was as "correct" as checking what's happening at the 12V battery itself in considering parasitic draw. I also wasn't sure if opening the hood would turn on some electronic system that would suggest an abnormally high load. You seem to be suggesting that the under-hood terminal is an OK way to test for parasitic draw. Since I have disabled SKS, that shouldn't be a problem.
  2. JC91006
    16,769
    8,567
    I actually don't think you have any parasitic draw, if your car is completely stock without modifications.
    I suspect the batteries you installed are not getting a good connection, not fully charged when you installed, corroded terminals, etc thus causing charging problems......and battery dying a premature death.
    But you can simply check your voltages and see if it is indeed losing charge.......that's simple if you use the front jump points to check
  3. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Thank you. As far as cleaning all of the terminals, ground cable connections, etc: do you recommend anything beyond scrubbing them with something like a green scrubber pad or sandpaper? Do you think I should replace any of the cabling in question?
    The last battery was purchased in April. Do you think there's any chance of recharging it? My allegedly fancy charger, described earlier, has a desulfication program among others.
  4. JC91006
    16,769
    8,567
    Most batteries come with a 2 year warranty now.....it's not even prorated, it's a straight out replacement.
    You can also try charging it at 4amp overnight and it should do the trick. If you've been charging it at higher than 4 amps (I think optima will take 10 amps), then you can damage the battery
    Do you see corrosion at the terminals? Is the negative cable tight against the body of the car?I'm wondering if your constant charging of the battery would kill it. Maybe you should just try and let the car charge it as you drive....nothing more.
    How long is your drive?
    #24 JC91006, Jul 14, 2015
  5. KEF
    KEF Junior Member
    38
    Sacramento, CA
    My wife drives the Prius quite regularly for her daily work, commuting ~70 miles on a good day and up to 100 miles when she has to work at the most distant facilities. We also take fairly regular roundtrips to San Francisco (86 miles one way) and LA (380 miles one way.) The car gets a lot of regular exercise.
    I was wondering about the constant charging being a possible culprit. However, I didn't try any of the solar charging or trickle charging described earlier until two new batteries had failed.
    I'm going to examine the attachment of the ground cable to the body, and clean all of the connections, and make sure everything is snug, and maybe try one more new battery. I recognize that is possible (though improbable) that we've killed multiple batteries by different means each time, maybe once with SKS, once with dirty terminals, once with overcharging. I do not know. The more times this happens the more I wonder if there isn't something else at work here.
    I wish there was a way I could experiment with cheaper 12V batteries.
    I'll pull the battery tonight or tomorrow and let the group know if I find anything incriminating. Thanks to everyone, and if you have any other brainstorms, please feel free to add your ideas. It would be satisfying to track this gremlin down!
  6. JC91006
    16,769
    8,567
    Why haven't you claimed the warranty on the batteries? It doesn't get cheaper than free under warranty.
    I was thinking the 12v charging system might be bad and you haven't noticed it is because you charge the battery manually all the time. BUT, I'm not sure how you can make a 380 mile drive with a bad charging system.
    I would go somewhere and get the car scanned for codes......it could very well be your charging system and you just can't tell because you charge your 12v manually
    #26 JC91006, Jul 14, 2015
  7. KEF
    KEF Junior Member
    38
    Sacramento, CA
    That's actually why I bought the Exide battery: it has a much longer warranty. In the past I've just bought new batteries out of expediency, and also out of a sense of ethics: if it's my car that's killing it, it isn't completely fair to the battery people to claim a new battery under warranty. But I've bought two of the very expensive Exide batteries now, and the last one so recently (April) that I'll probably return the battery for replacement if I am unable to recharge it.
  8. JC91006
    16,769
    8,567
    I believe I read you can connect 2 batteries together in a series (you should double check this series or parallel stuff lol), that will help your charger charge up the batteries that are really dead.
    Here's a video
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    what you have to do is get an ammeter, put it between the positive cable and the positive post on the battery. roll a window down so you don't lock yourself out of the car, shut everything completely off and lock the car. what you will be measuring is the "quiescent current draw". after 5 or 10 minutes when all the control units are supposed to have gone to sleep, the current draw should be < 20 mA or something very low-- I'm not sure what Toyota's spec is. if its drawing like 120mA after 30 minutes, you have a draw-- usually its because a control unit has an internal problem. if you do have a draw, you have to remove fuses 1 at a time until the draw goes away. its a real PITA, but that's what we did at the Benz dealer all the time because that junk had a lot of problems with killing batteries due to bad control units.
    if you don't have a draw, perhaps something with the key must be waking it up and killing the battery.
    valde3 likes this.
  10. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    I think in a (gen2) Prius it’s easiest to measure the current by disconnecting the ground cable where it attaches to body. And while doing this you’ll also see if cable has good connection there.
    If there isn’t parasitic draw then check the battery voltage from battery terminals with multimeter while Prius is in ready. Voltage should be 13.6…14.4V. If voltage is fine drive it for some time and then check it again (without turning the Prius off in between).
  11. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    just mount a switch by the rear passenger door to the battery..no need to open the hatch, Toyota might replace the battery free once than you will be out the money...you have a short and the labor to rip the car apart to find it exceeds its value unless you do it yourself ..did you call Luscious Garage | Hybrid Specialists ? they are near you and know what they are doing..if you want cheap buy the switch and wire ..you don't have a lot of options when its an electrical issue
  12. Patrick Wong
    18,210
    6,510
    Your car logs so many miles daily, that normally the 12V battery should enjoy a very long life.
    Use your multimeter and determine what is the voltage when the car is READY, and when it is IG-OFF after the car has been idle several hours. Measure the voltage either at the battery or at the dedicated jumpstart terminal to body ground.
    As previously suggested, make sure that the battery cables and connections are clean and tight, especially the negative cable where it bolts to the body. To remove corrosion, you can use an auto battery terminal cleaning tool (which is basically like a wire brush for the terminal) and you can use fine sandpaper on the metal lug that attaches to the body ground.
    You asked how to test the amount of current going into the 12V battery when the car is READY. This is easy: just connect your digital ammeter between one of the battery cables and the corresponding battery terminal. However, you need to be aware of the maximum current rating of your meter (usually 10A for a decent digital multimeter) and if the current flow exceeds that, the meter's fuse will blow.
    My method to test quiescent current draw is to open the hood, find the dedicated jumpstart terminal located in the main relay/fuse box next to the inverter, then use a 10 mm socket to remove the nut nearby. After the nut is removed, use long-nose pliers to pull up on the wire that is attached to the threaded stud.
    Now the 12V battery is disconnected from the fuse box. To measure quiescent current, attach your digital ammeter between the removed wire terminal, and the stud. Lock all doors and the hatch and keep the Smart fob well away from the car (more than 15 feet away). It is OK if the hood is up (at least with my 2004, that was the case.)
    Let the car's electronics settle down. The quiescent current draw should be ~ 0.02A (20 mA). If it is much more, then start pulling fuses to determine where the problem is. DOME would be the first fuse to pull.
    You may need to purchase jumper wires with alligator clips to make it easier to connect your digital multimeter to the car (Radio Shack is one potential source.)
    You can obtain the electrical wiring diagram for your model year at techinfo.toyota.com and that would be highly useful to give you a clue about what fuses are likely to try, during this process. This will also help if you want to assess the likelihood of removing a fuse as a way of deactivating a circuit because you don't use that feature.
    Yes, the Toyota dealer in principle should be able to do this, but the reality is that if a DTC is not logged, you may be asking too much for the auto tech (not trained as an electronics technician) to do this successfully. They'll probably charge you for two hours of labor and say "no trouble found".
    So it is up to you to gear up with the necessary information so you can DIY, if you are serious about keeping the car. It sounds like you have the needed equipment on hand.
    And if you decide your DIY skills are not up to the task, you can try Luscious Garage in SF as previously suggested.
    #32 Patrick Wong, Jul 15, 2015
    valde3 likes this.
  13. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I've recently learned from this forum that there is more than one level of charging the 12V from the inverter. You've mentioned measuring the 14+ volt mode. It sounds like there is also a lower voltage mode. Maybe others could answer if it's possible your car is constantly overcharging the battery?
    I agree with the suggestion to temporarily disable the solar charger. And to get a Toyota battery and start fresh--give it one more shot. The difference in mpg vs. the Camry, with the mileage you drive, could make it worthwhile.
    It sounds like SKS has been ruled out, but check that the SKS indicator light on the dash does not flash when the SKS switch is off and the car is off.
    I'd use two tools to clean the Prius ground cable--a flat file on the cable terminal and a wire brush on the body to get to clean metal. The attachment point is just a few inches away from the battery and as always, be careful when working around the positive terminal. But by this time you've probably put that issue to bed.
    Whenever I solve this kind of unusual problem after hours of looking (I'm a retired EE and a life-long amateur mechanic), I wonder how long it would have taken your average mechanic to find it, if at all. So often it's a matter of poring over a wiring diagram, finding pin-out diagrams and function tables, tediously checking continuity and device functions and outputs. (And in the last decade or so, spending time on the forums.) I look at it as good hobby and it's rewarding when you fix it. Good luck with this problem.
  14. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Many thanks to everyone for the detailed suggestions and input. I agree this should be fixable, or at least diagnosable. If nothing else, I would love to learn where the point of failure was. I'll be working on this over the next couple of days, and I'll be sure to update the thread when I identify what exactly the issue is.
  15. 69shovlhed
    2,170
    751
    Delaware
    my wife's '05 has an alarm on the hood. if you do your current test under the hood (thanks for the tip, Pat) you will need to close the hood latch-- unless there's a separate hood switch somewhere which I didn't see-- or the microswitch in the latch might keep a control unit awake and set off the alarm.
  16. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    One thing I see no one has suggested thus far.
    Go to the 12 V battery compartment in the rear of the car and remove the red protector cap that is over the +ve terminal. It has three clips -- LHS, top and RHS towards the back of it holding it in place. These just lever outward on the left and right sides and then the cap swings up and away.
    You should see a white harness clip that you can just press in on the locking tab and remove the plug. (This will reset your radio stations and a couple of other things (Clock) and probably reset some DTS's). Check both the socket and plug for corrosion and/or loose connections and clean or fix as necessary.
    If it looks clean and tight, push it in and then remove it a couple more times, then on the final push make sure it is in good and tight and locked in place. Replace the red cap, it just clicks on. Let us know if that helps.
    If you have a clamp-on meter that has a DC current setting then that will make life easy. Set it for 200 Amps and just clip it over the big black lead (-ve) coming off the battery on the right, as you look at it. Check, also, that the other end of that black wire is attached firmly to the car body and looks clean and free of corrosion. Try and orient the display of the meter so you can see it from outside the car.
    Set your Voltmeter to the 20 or 200 V scale, doesn't really matter, use the one that gives you the reading that looks right to you. Place this also in a position where you can see the display from outside the car. Connect the red lead of the Voltmeter to the +ve (red) battery terminal and the black lead to the -ve (black) terminal of the battery. You may need to use a couple of short leads with alligator clips on both ends to ensure the Volt meter leads are firmly attached to both the Voltmeter and the 12 V battery. Also make sure no part of the Voltmeter probes or clips have any exposed metal that is able to contact any other metal part -- it is a good idea to use a small rag or such like to wrap around any exposed parts of the Voltmeter leads to insulate them.
    Make sue that both meters read something (you may need to switch on ;-)) and then close up the car. Next, look through the window note down the date/time on a piece of paper and the voltage and current that you are reading.
    If the battery is good you should may be get 12,7 V or better (ideally up to 13.1 V) and the other meter should show some -100+ mA (I think, but don't quote me on that, it might be more). Your current readings will be negative as you are reading the current as it leaves the battery.
    After about 20-30 mins you should hear a couple of relays click in the front end under the hood. At is time you should observe the current reduce on the Ammeter to something like -20 mA (or about -50 mA, if the SKS is on).
    Let us know if that provided any answers.
    Hope that helps.
    #36 dolj, Jul 16, 2015
  17. KEF
    KEF Junior Member
    38
    Sacramento, CA
    Thanks, these are great suggestions. I do have a clamp-on meter and I will do the tests you describe. In terms of my progress, here's where I'm at now, and some interesting things I discovered ... they might point to the source of the problem this time around:
    1) I pulled the battery last night to charge it outside the car. Car interior lights, etc. seemed completely dead initially, and indeed I had to jump start the car just to open the trunk. HOWEVER, as I was messing around with all of the screws and harnesses in the rear to remove the 12V battery, the car burst to life at one point, with the interior lights going on strong and many of the panel lights coming on. Strangely, gauges like the numerical speedometer lit up, but AFAIK, the key that we use to start the car and insert in the Prius' key-slot receptacle was not placed in that receptacle. Hmmmmmmmmmmmmm....
    2) When it came time to disconnect the positive terminal, I noticed that it was attached *very* loosely. Like, as in there was a visible gap around the post. There was not any need to even untighten the screw that clamps the terminal thingy to the battery post. I recall when I installed the battery this last time having some concern that I didn't want to bend or break the lead terminal ends, so I did not overtighten the terminal's screws at that time, but it was really, really loose last night.
    Can someone advise how tightly I should be cranking on the terminal's screws, and what I should be buying so I can have a replacement around if I break the soft lead terminals? Ideally something I could order from Amazon. I do own torque wrenches if we need to be exact. I found it a little troubling to see the terminals bending when I was attaching it earlier.
    3) Once I had removed it from the car, I started charging the 12V battery and found that it charged up very quickly. Alas I didn't take a multimeter reading off of it before I started charging, which was a mistake. After charging, the battery read 12.98 volts last night, according to my multimeter. I took a reading off it this morning (after it had been sitting all night, not charging) and it reads 12.93. Any thoughts on whether this battery is good or not? I imagine the real test will be how it behaves under load.
    If you think I'm wasting time by trying to charge this battery, which was manufactured in March and which I bought in April, please let me know.
    4) I've ordered battery post and terminal cleaners (fancy wire-brush doo-hickey) as well as a spray cleaner for corrosion (a Pematex product:
    ) . I have also ordered a protectant that is supposed to prevent future oxidation of the terminals. (also a Pematex product:
    ). I have sandpaper already. When all of this arrives late today or tomorrow I'll use it to clean all terminals and the ground wire.
    5) I bought the service manuals and the wiring diagram for the 2005 Prius. When it comes time to test the vehicle for parasitic drain, this may be useful.
    Next step will be to put the battery back in the car after I've cleaned all terminals, harnesses, ground wire attachment, etc. I recognize that I might have fried the battery somehow and may need to get a new one, but I would like to test carefully for parasitic draw before putting a brand new battery in place.
    The fact that the positive terminal was attached so loosely would seem to be quite damning, and an easy explanation for these problems. But I'm not convinced that's the entirety of the problem: this was, after all, the third battery we've run through in a relatively short period of time. I'm going to look carefully at everything before declaring victory.
  18. valde3
    2,002
    749
    Finland
    1) So it was completely dead and then you touched some wires and it worked for a moment? This means that you just have bad connection somewhere. Instrument panel lights flashing as you connect the battery are normal.
    2) You shouldn’t have to tighten the screw very tight to get the terminal tight on battery post. So probably something is broken. Probably this is the same thing that causes your charging problem.
    3) Voltage is good. It’s probably good enough for Prius.
    I think that if you just get the cables connected good it will work fine. When you get this working please post us your fix.
    #38 valde3, Jul 16, 2015
  19. KEF
    KEF Junior Member
    38
    Sacramento, CA
    One other thought. I have a strong background in computers/programming, and have a lot of computers lying around. I now own two 2005 Priuses. I saw that Toyota sells some software with a hardware interface for the Prius. This presumably gives you a bunch of diagnostic information. Would there be value in buying this, for this problem and for future issues?
  20. bisco
    51,952
    maybe there's something wrong with the threads, you really shouldn't need to torque the clamp onto the post. you should be able to snug it down tightly without damaging anything. are the battery posts the correct size?
    the battery sounds like it's good, so reinstall it, check your voltage every morning for awhile, and keep an eye on the connections.yes, buy the mini vci on amazon, it's the best prius diagnostic tool and only $25. look around here for many threads and info.
    #40 bisco, Jul 16, 2015
