Prius with a few codes: need advice
Discussion in 'Generation 1 Prius Discussion' started by PriusWI, Jan 27, 2013.
  1. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    So I just scanned the battery block voltages... 17,18,and 19 all read much lower than the rest when I scan but none read zero. I when I check them with the multimeter they all show good equal power.
    Should I just take the harness off and give them terminals and sensors and nuts a good cleaning and try again?
  2. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    Update....
    I'm assuming this caused the 3030? I discovered this behind the connector on the 39th module.. Is there a place I can just buy a new connector? Or do I need a whole new harness?
    Could this have been causing problems all along?
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    That looks like a whole harness to me but, I can't see where it hooks on at the other end. I'm nearly 100% positive you won't be able to buy just the part that's broke.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Just use some scotch tape, or metallic duct tape and you'll be fine......................
    JUST KIDDING. Do not do that! :)
    You will not be able to buy that as a separate Toyota part. Get a harness from a recycler like adopt-APart that specializes in hybrids. Or you could check with anyone who sells used battery slices. Maybe they have an old harness sitting around they would sell you?
  5. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    Wow. Thank you (everyone who helped) for all the support and advice.
    I ended up taking apart the battery 3 times because of different codes I had to overcome in the past two days...but after a LONG code free drive I am finished!
    I was able to find a new harness at a junkyard today,threw it in put it back together and were running great. All blocks charging at the same rate.
    Best advice was to get an obd scanner. I was able to use an ELM obd Bluetooth adapter along with the torque app and the custom PIDs from the other thread to diagnose, scan, and now log the information that I need.
    I would have never been able to do this with out all the input! I took a bunch of pictures along the way...I'll try to get some up later.
    Thanks again!
  6. ChapmanF
    19,050
    For anyone considering rebuilding a Prius battery, there is a part number for a rebuilding kit that includes shiny brand new busbar assemblies including the sense harness as well as some insulating resin sheets for the ends of the battery stack that were an addition to the original design. The part number can be found in the original battery re-sealing campaign PDF, which is kicking around on this forum in several places. I bought a kit a few years ago just in case I might need to open up the battery; it wasn't very expensive.
    I'm sure it's more money than parts from a salvage yard, but I'd guess that any busbars from a yard are going to show some degree of corrosion.
    -Chap
    Edit: of course there are also the improved, nickel-plate busbars from ReInVolt; I don't know whether they offer those for sale a la carte.
    yotatoter and usnavystgc like this.
  7. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    So I got another bad battery code...and i didnt feel like replacing another module..so I bought a Reinvolt battery...
    I thought that would be the end of my problems...
    After clearing the codes, replacing the battery with the reinvolt pack, and driving it for a day, the P3006 code came back!!!
    I called and he told me to reset it..so I cleared the code again, and guess what? the P3006 code came back again today? Bad reinvolt battery?
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    What is 3006 again, is that the code that just basically states there is too great of a voltage diff between modules?
  9. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    yeah battery levels unusually different..
  10. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    which from everything I've read means, replace battery...I JUST REPLACED IT! (n)
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    Probably not a bad pack but maybe just an unbalanced pack. I would continue to work w/ Reinvolt. They have a great reputation for standing by their product.
  12. usnavystgc
    3,159
    990
    Tucson, AZ
    Well, IMO, it doesn't necessarily mean replace but "balance" the pack (but that's just my opinion).
  13. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    Yeah..just sucks that they sell a "turn key" product I shouldn't have to do anything except install it...
    hopefully this can be made right, quickly.
    is there any chance that the code could be something other than the battery? doesnt the HV battery send the 3006?
  14. usnavystgc
    3,159
    990
    Tucson, AZ
    I'm no expert but I believe that's true. You know I gave this advice in a prior post but others disagree with it. You can run it by ReInvolt or do what you want with it. I personally can't see it causing any harm either way. Here it is.
    Here's what I would at least try if this were me (no guarantees but it makes logical sense and its easy to do).
    Drive the car on a flat surface below 42mph and hold in EV mode for as long as possible (trying to run the HV battery down as low as possible) The idea is to get it into the purple bars. Run it until the ECU's automatically fire up the ICE to begin recharging the battery (this doesn't have to be done while driving, you could also do it by simply turning it on and letting it sit. The main focus is to drain the hv battery as low as the ECU's will let you). Then, drive it to a long downhill stretch and coast down the hill in drive (attempting to get the battery to 8 bars). If after this, you have codes, clear them. Drive the car and see what happens.
    The idea behind this is to attempt to balance the pack using the cars charging system. I might even do this 2 or 3 times. I would give this about a 10% chance of helping you.
    Of course you don't have bars in a Gen I but, you get the idea. Like I said, the chances of this fixing your problem are small but, without taking the battery apart and balancing modules, its all I can think of.
    B4 doing this, please be sure to run it by ReInvolt. Although I don't see how it could hurt your pack, I wouldn't want to be responsible for giving you the advice that voided your warranty.
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    I guess there's a chance it could be the sensing wires but I believe those are part of the ReInvolt pack (I've never bought one but, I'm pretty sure that would be a part of it).
    Either way, you don't want to void your warranty with Reinvolt. How does the car drive? I'm guessing it drives just fine.
  16. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    Yeah it came in the case with the ecu and everything installed...
    Not bashing them... But after talking to reinvolt two times about the issue.. I'm not seeing this amazing service that most speak of...
    He was telling me that the 3006 is a hybrid fault code that is not specific to the battery... That doesn't line up with everything else I've read.. So correct me if I'm wrong but the 3006 is the battery right?
  17. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, thats my understanding but as I said, I'm no expert. Logically, its the battery ECU which monitors battery voltages (that's how you get the unusually different levels DTC aka p3006).
    That's too bad about the service. I've never dealt with them. I hope (and suspect) they will make it all right for you.
    Does the car drive well?
  18. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    Drives fine... For now
  19. usnavystgc
    3,159
    990
    Tucson, AZ
    Its hard when we pay hundreds of dollars for something and it doesn't work like we want it to. I know your pain. I paid for a PHEV kit from PIS that I never got (long story) and only got half my money back. Whenever I see good things about them posted here, I just roll my eyes.
  20. usnavystgc
    3,159
    990
    Tucson, AZ
    And that's what I would expect from a 3006 fault with a new pack. And it should continue to drive fine for a long time. IMO, 3006 is a minor fault but it is irritating to have the CEL and Hybrid lights up all the time.
    Work with them and you might try contacting Bob Wilson. He appears to have a great relationship with ReInvolt.
