Prius with a few codes: need advice
Discussion in 'Generation 1 Prius Discussion' started by PriusWI, Jan 27, 2013.
  1. bwilson4web
    16,552
    What sort of scanner do you have?
    If you have one that can read out the 19 module pairs, we can quickly identify the problem(s).
    usnavystgc likes this.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Great timing Bob.
  3. bwilson4web
    16,552
    Depending upon how far off, it will. We need metrics to understand what is going on.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    I'm going to bow out for now. The expert has arrived and its time to "knock off".
    Good luck.
  5. bwilson4web
    16,552
    You did fine. <grins>
    As for expert, we're all pretty much that here. Best of all, we're not jerks about it!
    Did you try contacting Eric Powers? I believe he is in Madison WI and a good local resource.
    ps. I've offered to loan my extra miniVCI while waiting to find out if anyone is going to buy it. He'll be done by the time I need to forward it to the next owner.
  6. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    I've been using the torque app with the custom pid from the other thread... So I can read the individual modules, they seem pretty consistently the same..
    What outside of what I got from reinvolt could cause that code? That's what I'm interested in knowing. I bought it from them because I was getting sick of fiddling with the car I just wanted it fixed.
  7. bwilson4web
    16,552
    Do you have:
    • minimum block voltage
    • minimum block index
    • maximum block voltage
    • maximum block index
    Not enough information to tell and the reason why:
    1. Code points you towards an area of interest
    2. Use data from that area to diagnose what is going on
  8. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    But isn't that "area of interest" confined to something that is inside the battery case somewhere? Hence the 3006?
    I mean it's not like an open gas cap is going to send that code
  9. bwilson4web
    16,552
    The three primary ECUs save error codes:
    • Engine ECU - three
    • Hybrid Vehicle ECU - three
    • Battery ECU - three
    We need to know all codes and by which ECU to understand what is going on. This should include the letter prefix which lets us know the code scanner is prius-aware.
    The next step is to measure the minimum and maximum traction battery voltages. With a Prius-aware scanner, we measure all 19 module pairs but it is usually enough to measure:
    • minimum module-pair voltage
    • minimum module-pair index
    • maximum module-pair voltage
    • maximum module-pair index
    The voltage difference and index changes tells us:
    1. Less than 1.2V - a soft problem, possibly unbalanced module, can 'cure' itself with use.
    2. Over 1.2V - a failed module, can not 'cure' itself.
    3. Low voltage pair fixed - a single module pair has a problem and unlikely to fix itself.
    4. High voltage pair fixed - a single module pair may have a problem. and may or may not fix itself.
    5. Zero voltage - a sense wire has broken, another code in addition to the P3006. This is why all codes are necessary.
    6. Reproducible or intermittent - perhaps there is a loose nut or failing connector.
    7. When does the error happen? - always when the car is first turned on or after driving "n" minutes
    The other thing we need are the four, traction battery temperatures. Three are from the pack and the fourth is the ambient air temperature. A failing battery will show a rapid temperature change in excess of 3C as a failing module runs hotter than the others. What are your four traction battery temperatures?
    Now you may have a loose gas cap too. The only way to tell is read out all nine codes from the three, primary ECUs. You might also have some brake and other car issues. The only way to tell is to have a Prius-aware scanner that accurately reports all facts and data.
    When I was qualifying ReInVolt about four years ago, we discussed the technology they use and business practices. I understand they had one warranty repair out of hundreds which seems about right. Also, there have been problems with damage in shipping.
    The traction battery assembly weights nearly 100 lbs and shippers are notorious for poor handling practices. Installers are not always as skillful as they should be. But even so, we had to do a little 'metal bending' on the first ReInVolt pack . . . 'some assembly is required.' But ReInVolt needs the same information I've asked for before being able to make a warranty call.
    One last thing, I'm Southern and so too are ReInVolt. A little courtesy goes a long way South of the Mason Dixon Line but your comment about 'gas cap' does not help. Most of us posting here work 'for free' but our patience is not unlimited. Like the Monty Python skit, 'the argument,' this is not 'abuse.'
  10. PriusWI
    PriusWI New Member
    26
    2001 Prius
    I
    Thanks Bob.. .
    It seems you indirectly answered the question I was asking. All the issues it *could be* from the P3006 code are relating to something from the battery.
    I completely understand why you want me to have all that data and what not and I can have that information using my scanner. I also understand that accidents happen with shippers and what not.
    I was just voicing my frustration that I should not have to do all that kind of stuff when going the reinvolt route of replacing the whole thing. You would hope that you just get a good battery with no issues the first time and that your not one of the very few that has a problem.
    Thanks for the helpful info...
    I also am saying that, as someone who spent 20 years of my life living in the south, below the mason Dixon line, about an hour from where his shop is located, people were much more polite from the get go then he has been. When I call he does not sound too interested in answering my questions he seems more interested in hanging up when I ask things with plenty of southern courtesy. That's all I speak of when I say I'm not seeing the amazing service. And thanks for the lecture...
