Prius With Tesla Lithium Ion Batteries?
Discussion in 'Gen 2 Prius Technical Discussion' started by HBS, Jan 30, 2019.
  1. HBS
    HBS Member
    74
    56
    MO
    Has anyone tried making one of these, is it possible and would it work?
    52,863
    mine has lithium ion, works great! tesla would be better, but might need different management,and not sure about fitting the space.(y)
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    This is the gen 2 area Bisco. I think all gen 2’s have NiMH battery’s. To the OP I think the computers are the main difficulty with making lithium batteries work. If you decide to attempt this please keep us informed. It sounds like an interesting project.
    52,863
    is gen 2 before 2012?(n)
  5. python777
    python777 Junior Member
    Alexandria, VA
    Nope gen 2 is 2004-2009 I believe, might be a year off on the launch year.
    iPhone ?
  6. dolj
    dolj Senior Member
    8,652
    4,401
    Wellington, New Zealand
    Not to be confused with the Gen 2 PHEV, which were all based on the Gen 3 Prius.
  7. bisco
    52,863
    don't the euro gen 2 have lithium? and run through 2010?
  8. Prodigyplace
    12,716
    11,849
    Central Virginia
    Gen 2 PHEV (Prius Prime) is based on the Gen 4 Prius (2016+)
    The Gen 1 (2012 - 2015) was based on Gen 3 Prius refresh.
    SlidingBike and jerrymildred like this.
  9. dolj
    dolj Senior Member
    8,652
    4,401
    Whoops! Mea culpa
    Thanks for picking up on that.
    Prodigyplace likes this.
  10. HBS
    HBS Member
    74
    56
    MO
    Why do you think the computers would be the difficult part? Thank you.
  11. HBS
    HBS Member
    74
    56
    MO
    Do you know how many it would take?
    The 90 Kwh battery is made of 16 modules . Each module has 444 cells arranged as 74 cells in parallel and 6 of these 74 cell units in series. Each module has an output voltage of 4.2 * 6, or 25.2 volts. These 16 modules are then connected in series to provide 16 * 25.2 , or 403.2 volts. The lower capacity batteries only have 14 modules in series, so their output is 14 * 25.2, or 352.8 volts.
    #11 HBS, Feb 3, 2019
  12. bisco
    52,863
    how many would it take to what?
    physical size is your issue. how much of the hatch do you want to fill?
  13. bisco
    52,863
    you would have to be competent enough to go into toyota's proprietary battery management software and make adjustments for battery chemistry and size
    Skibob likes this.
  14. bisco
    52,863
    are you looking to make a plug in, or just replace your pack with tesla cells?
  15. Mithrandrost
    Mithrandrost Member
    30
    2018 Prius
    Retrofitting a vehicle with Tesla batteries can be done, but is not easy and comes with risks like thermal runaway. Check Rich Rebuilds:
  16. Prodigyplace
    12,716
    11,849
    Central Virginia
    The computer charging software circuits and wiring were designed for different battery size and chemistry. The computers were not designed to be field modifiable.
    My question is why do you think it would be easy??
    Skibob likes this.
  17. HBS
    HBS Member
    74
    56
    MO
    Replace with Tesla cells to build new replacement hv batteries.
  18. HBS
    HBS Member
    74
    56
    MO
    So then batteries like thes are nimh and that’s why they can work?
  19. bisco
    52,863
    Gotcha. There are a few issues. Tesla cells are vastly different than Prius. They have liquid thermal control and appropriate battery software management.
    Anything can be done, but the necessary dkills and knowledge are rare.
    You won’t find any help here, only one or two have passed this way with that kind of ability.
  20. bisco
    52,863
    No idea what that battery is in your picture
