Prius won't go into drive with red triangle on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by my first prius, Dec 10, 2020.
  1. strawbrad
    953
    1,007
    Not sure what this means. What points are you measuring?
  2. jpkc97
    jpkc97 Junior Member
    47
    Update, bought a used battery today, expecting some bad modules. Figured I could use some of the good ones from my old unit for replacement. I found the expected middle 4 were bad, with 1 leaking 5.5v to ground and another .5v. The other 2 had black marks near where they mount indicating a short, yikes. But, my modules don't fit, they are too small. From the pictures I've seen I realize I had a Gen I series pack in the car. Now I need to find 4 more modules . The "new" module is shown in the foreground.
  3. ozmatt
    ozmatt Active Member
    636
    263
    Australia
    Seen my share of leaking packs but that one is quite bad
    jpkc97 likes this.
  4. jpkc97
    47
    Sorry, meant to mention that this was measured between the + terminal and the oxidized section of the battery.
