Prius won't go into ready mode after replacing 12v battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Scott M. Bleeker II, Aug 19, 2018.
  1. Scott M. Bleeker II
    Scott M. Bleeker II New Member
    Fairfield NJ
    The other day I started my 2005 prius and after driving a few miles I got the red triangle and pulled over somewhere safe to try to diagnose the problem. Upon turning the car off and on again it failed to go into ready mode, so I checked the diagnostic mode and the voltage of the 12v was fluctuating within the low 11s and high 10s so I decided that it was pretty much dead. I replaced the battery but the same problem still persists and I can't get the car to go into ready with the new battery resting at about 12v-11.9v. The brake lights also work perfectly fine so I'm pretty clueless on how to proceed.
  2. JC91006
    16,829
    8,601
    Did you mess with the orange interlock switch on the hv battery? If you did, just go back in there and lock it. Press/slide it downward towards the floor and you'll hear a click. That locks it
    52,398
    you need to charge up the 12v. although new, it has been sitting too long.
  4. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Check your grounds, they could be corroded or loose.
  5. Scott M. Bleeker II
    Fairfield NJ
    I tightened the ground from the negative terminal which was a bit loose but I'm still having the same issue. The battery is currently reading from 11.7-11.9v depending on what is being powered. What voltage does the battery need to start normally? >12v? Also I never touched the orange disconnect and it seems to be properly in place. I don't currently have a battery tender so I'm going to go out and buy one now
    #5 Scott M. Bleeker II, Aug 20, 2018
  6. Scott M. Bleeker II
    Fairfield NJ
    Scraping off the corrosion from all the connections seemed to do the trick! Thanks for all the help.
  7. RacerM
    RacerM Junior Member
    Just stopping by to say thank you. Attempting to diagnose the "Check Hybrid Battery" message and had left the lever unlatched.
