Prius won't go into Ready mode
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Enoblk, Apr 6, 2016.
  1. Enoblk
    Enoblk Junior Member
    36
    Oregon
    Bought the transmission control ECU but it's stuck in the flashing gauges and no HV battery mode again
  2. Plamen Petrov
    Plamen Petrov Junior Member
    Bulgaria
    Very unpleasant thing.
    Now we have similar situation.
    Checked all the fuses, replaced all ECUs - hybrid, transmission, engine, battery sensor and there is no way to get ready sign on the dash board.
    Thinking to replace the inverter - the only thing we didn't till now.
    52,848
    do you have a code reader?
  4. Plamen Petrov
    Bulgaria
    Yes, the errors are:
    in Engine - U0293
    in Gateway - B1260
    in ABS/VSC/TRC - C1241, U0123, U0124, U0293
    Other error, not so stressful - C2318
  5. bisco
    52,848
    hmm, how many miles on her?
  6. Plamen Petrov
    Bulgaria
    not so much - only 230
  7. bisco
    52,848
    wow, that's low to be having problems already.
  8. Plamen Petrov
    Bulgaria
    SOLVED!
    With a help from my friend the car is running again.
    We changed the transmission ECU and studied the other ECUs.
    Changed the 12V battery, too.
  9. bisco
    52,848
    congrats!(y)
  10. F_Lv_K
    F_Lv_K New Member
    Singapore
    I have the same problem here. Not able to get into ready mode.
    Did you do any setting when replace the transmission ecu?
    Can I know the detail about the solution?
    Thanks
    SFO likes this.
  11. Sheetal G
    Sheetal G New Member
    San Jose, CA
    It took me a day to realize that I had forgotten the step-3, locking the plug in place. I am sure my Prius should start tomorrow. It was not going into 'Ready' state because of this for sure. Thanks for this graphic. I might still have to deal with if the 'red triangle' and the car icon with exclamation mark on the MFD appears again, this happens when driving on freeway. Do you think if I replace the 'Inverter Cooling Pump' this should be fixed?
  12. evaloper
    evaloper Junior Member
    Redlands, CA
    The recommended AGM battery doesn't 'need' maintaining, so I suspect you purchased the wrong type of battery. AAA came out and tested my battery and finding it was 10 YEARS OLD replaced it for $219. I'm back in business.
