Prius won't run.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fwbrc51, Aug 3, 2014.
  1. fwbrc51
    fwbrc51 Junior Member
    61
    Fort Walton Beach / NW Florida
    dl'ing the "paid for" torque app now.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    No, you can use the free version
  3. JC91006
    16,936
    8,647
    If your car was running properly before the oil change and dead battery, then that is where you would look for your problem. Try draining 1/2 - 1 quart of oil from your engine. Disconnect the CHARGED 12v negative for a few seconds and try again.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
  5. JC91006
    16,936
    8,647
    and make sure you have gas in the car.......
  6. fwbrc51
    61
    I just bought the paid version of torque. I don't see where you load any extra toyota plugins.
  7. fwbrc51
    61
    i'll drain some of the oil.
  8. bisco
    52,855
    my '08 was regularly a quarter inch over the max mark.
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Did you look at the thread I referenced? It is completely spelled out step by step with pics.
    Britprius likes this.
  10. fwbrc51
    61
    yep
    Yep. I just unzipped them as stated. I still get no errors through my ODB. Funny cause I also no longer get any error faults like before on the MFD, the codes I was questioning about. I'm at the point of calling a tow truck and sending it to the stealership.
    Any other help from others?
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    If your getting no DTC's on Torque and no lights/faults on the MFD, how is your car running? The dealer will not be able to tell you anything.
  12. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    I imagine you have tried to start it multiple times. Does it crank and fail to start or just pop up the lights without trying to start.
    Did you touch the orange service connector?
    The weak battery seems like a different issue if it still does not try to start after 4 attempts ( this clears the red triangle) and a battery charge.
