Prius won't shift to drive
Discussion in 'Gen 3 Prius Technical Discussion' started by Jaydoc, Feb 15, 2017.
  1. Jaydoc
    Jaydoc Junior Member
    30
    Birmingham
    Hi all
    My 2010 Prius was parked without being driven for 3 weeks. Now when I push the power button the dash lights up but the ready light stays off and the car won't shift to drive.
    Can someone help me figure this out?
    Thanks
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    Possibly the brake switch out of adjustment?
  3. mjkcal
    mjkcal Junior Member
    US
  4. mjkcal
    US
    The 12 volt battery needs a jumpstart (not the hybrid battery). Instructions begin on p 543 of the Prius 2010 Manual. Your dash lights up because the 12 volt battery is not completely discharged --but enough that it doesn't have enough power to start the car.
    Montgomery and Jaydoc like this.
  5. JC91006
    16,936
    8,647
    +1 Most likely dead 12v battery
  6. Jaydoc
    30
    Birmingham
    Thanks everyone. Like you guys said it was a dead 12v battery. I initially tried to jump start the car using the leads in the front engine compartment fuse box, but that did not work. Had to open the hatch and jump the actual battery in the back. That solved the issue.
    Thanks again.
  7. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Just curious, did you try flipping the jumper cable clamp around on the positive terminal in the fuse box? Only one side of the fuse box terminal is metal, and some jumper cables only have one side of the clamp that is connected to the cable so you might not have had metal to conductor contact. Also need to make sure the negative under the hood is connected to a good grounded bolt.
  8. Jaydoc
    30
    Birmingham
    I made sure of all that. Flipped up the clamp and made sure there was metal to metal contact at both terminals. Used the bolt that's behind the fuse box as well as the metal arm that holds the hood open as ground terminal contacts, and yet no dice. Used the same battery and cables on the 12v battery itself and got it to work on the first try. Then drove around for 15 mins just to ensure battery for charged up, as a precaution.
    carloz562 likes this.
  9. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Strange that the fuse box terminal didn't work especially since the Prius does not take all that much power to jump start like a conventional does.
