Prius Wont Start After Checking Spark Plugs
Discussion in 'Gen 3 Prius Technical Discussion' started by thommi7, May 18, 2020.
  1. thommi7
    thommi7 New Member
    Temple, Texas
    I was getting some bad engine knock and misfires on all cylinders. I removed my spark plugs to inspect them and now after reinstalling them the car wont start.
    All the warning lights are on
    I'm getting the dreaded "check hybrid" error message
    my 12 battery is reading over 12.4v
    the hybrid battery is showing about 3/4 charge
    the accessories are all working
    I know its possible that my plugs are bad. Before I buy new ones I would like to know if these errors could be caused by bad plugs.
  2. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Seems like you didn't reconnect something, or connected it wrong, which is hard to do.
    You should recheck everything, carefully.
    Does the engine turn over? Usually when you first turn it on it will be about 10 seconds before
    the engine starts.
    12.4 volts is kinda low, but it should start. Do you have a charger? 4 amps or less? Or try jumping it with a known good battery,
    or from another vehicle.
    It's not very likely you got 4 bad plugs. Which brand? Hopefully they are not the cheap china copy denso plugs.
    I use Bosch.
    Were the old plugs wet? Did you look inside the cylinders to see if you had coolant in them?
    Have you cleaned the egr cooler and related items?
    How many miles are on it? Hopefully, it's not the head gasket.
    52,819
    is the car making ready? 'won't start' is a very vague term for a prius.
    it's probably the 12v.
  4. thommi7
    thommi7 New Member
    Temple, Texas
    Thanks for the reply guys.
    I agree that it seems like I did not reconnect something properly, but not sure what that could be since hardly anything was disconnected.
    It doesn't seem to turn over at all.
    One of them had blackish soot. All of them were dry
    I'll charge the battery and try again.
  5. thommi7
    thommi7 New Member
    Temple, Texas
    Quick pic
    This is the what I see after hooking up the 12v, before attempting to start it.
    #5 thommi7, May 19, 2020
  6. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I don't see that he used new plugs -- just reinstalled the old ones.
  7. Mendel Leisk
    42,322
    How many miles on it?
    Do you know if the plugs are the ones from day one, from the factory?
  8. ASRDogman
    8,055
    4,083
    Okay, may seem silly, but did you press the brake pedal before pressing the start button?
    What is the voltage on the battery?
