Prius won't start, flashes the combination meter for a split second
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bigyums, Sep 10, 2022.
  1. Bigyums
    Bigyums Junior Member
    Lawrence, KS
    Hi Prius People! Please Help.
    I was driving home from work on the interstate about 65 mph, and all of the sudden there was a singular knock noise in the left front of the car. A small thud, and it was immediately followed by a caution - red triangle of death. At the time the MFD screen showed the HV battery at full charge, but quickly depleted as I pulled off the road. Engine stopped running as I was coasting to the stop. I turned the car off with power button, and tried to restart but it never would start again.
    Call the tow truck, we did try to jump, no issues with reverse polarity or anything like that. The jump didn't work, and nor did other 12v batteries.
    I checked the 100 amp fuse-link and it seemed fine. Checked most of the other fuses and nothing seems to be burned either, and the HV battery plug is in an has no issues either.
    Out of desperation I decided to change the 12v battery with a brand new battery that matched OEM. It didn't work.
    One other note. The HV battery was replaced this summer, with an Green-tec battery, but has not had any signs of trouble yet.
    Take a look at the video below where I try to start it, while holding the brake. The combination screen just flashes up for a split second and then seem to short out. Then the car does nothing.
    Battery powers up accessory mode just fine though. See video below.
    Does anyone know what I should check next. Thank you for your help in advance!
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    First thought is to see if the AM2 fuse in the underhood fusebox is blown. A common scenario is for the inverter coolant pump to fail and short - popping the fuse. That fuse also supplies power for the power source control ecu for most all "ignition on" circuits. Such as the combination meter (speedo) and ECM.
    If that fuse is blown, you can unplug the coolant pump and replace the fuse. There's a single wire (white with black stripe) connector near the left front strut tower underhood. That will disable the pump.
    The car should then run but keep the drive slow and not too long (no A/C) - otherwise the inverter will overheat and turn off. Then you would need to replace the pump- I only use a Toyota part as aftermarket parts have questionable reliability.
    52,807
    put it on a lift to see if you hit something
  4. Bigyums
    Lawrence, KS
    Thank you for the input! I doubled checked the AM2 fuse just now. It’s still good, visibly good, and took it out and tested for continuity ok.
    Just for curiosity I unplugged coolant pump after putting the fuse back in to see if that any effect. It did not, it’s doing the same thing.
    Any other ideas?
  5. Bigyums
    Lawrence, KS
    It was a clear road, and during the day. I’m certain I didn’t hit anything, but thanks for the idea.
  6. mr_guy_mann
    4,111
    2,011
    NJ-USA
    I would scan all the ecu's on the car with a capable scantool and see which ones respond. That would give clues as to which systems are working.
  7. Bigyums
    Lawrence, KS
    Can't read the codes. Scanner and Tech Stream both won't recognize it right now without the car turning on.
    #7 Bigyums, Sep 16, 2022
  8. Bob!
    Bob! Junior Member
    Austin, TX
    2014 Prius v wagon
    I have a similar (if not identical) problem. Any luck finding a solution?
  9. Bob!
    Bob! Junior Member
    Austin, TX
    2014 Prius v wagon
    My profile says I have a 2013 Prius v (I do), but I also have a 2002 Prius and this is the vehicle with the above problem. Not sure how to add a second vehicle to my profile...
    But would love to fix the '04 that is experiencing the same prop that the OP is inquiring about.
  10. Bigyums
    Lawrence, KS
    Yes! Mine is fixed. The issue turned out to be a fried ECU board, behind the glove box. I have no idea how it spontaneously blew, but the replacement ecu has been working fine for months now.
  11. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    ECU board? Or do you mean PCB?
  12. Bigyums
    Lawrence, KS
    ECU 89661-47070
    SFO likes this.
  13. dolj
    dolj Senior Member
    8,635
    4,389
    That is the engine management computer (ECM).
    Interesting that it should fail in the way you describe.
    It is a shame you could not pull codes as that would have been interesting to see what they were, though not surprising with a failed ECM.
    Glad you got it sorted and are on the road again with the 2004.
  14. Bob!
    Bob! Junior Member
    Austin, TX
    2014 Prius v wagon
    Thanks for the update! I was kind of thinking it might be one of the car's brains. Haha.
    How did you conclude that this was the failing part? Was it visibly fried? I'm hoping to diagnose mine and repair. And did you swap it out yourself? Thanks again.
    -Bob
  15. Bob!
    Bob! Junior Member
    Austin, TX
    2014 Prius v wagon
    Well, that wasn’t the problem. Or wasn’t it?
    I bought a used ECU from eBay and put it in today. The car turns on for a split second and then back off, as described in the following linked post where I started a thread about my non-start prob: 2004 Prius won’t start up. Died while driving. Warning lights blink then shut off. | PriusChat
    After reading this thread, I thought my ECU might be bad. Now that I've swapped it, either my ECU wasn’t the problem (and I, once again have no idea what the problem is) or the used ECU I bought is broken in the same way as mine.
    It might seem unlikely that the used eBay ECU failed in the same way as the original but I did once buy a used ABS actuator for a Gen 1 Prius and put it in (huge pain in the rear) only to learn that it did not work at all and wouldn’t even power up. So, it happens… ugh.
    If anyone has any ideas or suggestions, I’d appreciate it.
    Thanks.
    #15 Bob!, Jan 3, 2023
  16. Bob!
    Bob! Junior Member
    Austin, TX
    2014 Prius v wagon
    UPDATE:
    I re-checked the AM2 fuse and it’s blown. Swapped the fuse and unplugged the inverter coolant pump and it started right up. Plugged the inverter coolant pump back in and started it up. Started smelling burny and smoke wafted up from the inverter coolant pump. Turned it off and ordered a new inverter coolant pump. Sounds like this was the problem all along. Ill update when I get the new inverter coolant pump in there.
  17. cgalpin
    cgalpin Junior Member
    Northern VA
    Did this require any re-programming, and if so how did you do that?
    I am facing the same problem on a 2005 - can't start or go to ign-on, so can't get any obd2 reader (including techstream) to communicate with the ECU. All fuses including AM2 are fine, 12v battery good, have disconnected the white + white/black wired connector to the coolant pump near the fuse box. Headlights, radio, brake lights work.
    I am considering buying a used ECU to see if thats the problem, but want to make sure it doesn't need programming or there is a way to do this.
    #17 cgalpin, Jul 19, 2023
