Prius won't start, lights not on
Discussion in 'Gen 2 Prius Technical Discussion' started by AClon, Jun 30, 2019.
  1. AClon
    AClon New Member
    San Diego
    I went to start my 2005 Prius, and all the lights in the car flashed on for a moment then died. I can't start my car, no dome lights came on. I was able to jump it easily and drive fine, but once I turned my car off it won't turn back on again. I assume the 12v battery is dead, but the lights flashing on for a moment and then shutting off has me worried it was some sort of fuse or something else. Any thoughts?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    If you could jump it you probably have a dead battery. There is a fuseable link in the positive battery terminal though. After you start the car check the voltage at the battery terminals and let us know what it is.
