Prius wont start or go into gear, gear lights flashing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MAXsandwich, Jun 10, 2014.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    ^^^What he said.....I'm sure by now they figured it out.
    VS980 4G ?
  2. robl45
    robl45 Member
    137
    I have this same problem. Did anyone ever figure it out?
    51,968
    probably a bad 12v
  4. robl45
    robl45 Member
    137
    I am charging the 12v now. I am hoping to not have to drag out the code reader.
  5. bisco
    51,968
    don't blame you, how many miles on her?
  6. robl45
    robl45 Member
    137
    About 151k. Was running fine then all of a sudden while waiting at light problem triangle came on and it went into neutral and all gear s started flashing and had gauge flashing
  7. robl45
    robl45 Member
    137
    Still trying to charge it, hooked it up to a faster charger now. I'm pretty sure the battery was within range to start it last night though. I will try again before I have to leave, then I suppose I have to drag out the scanning stuff and attempt to get it to connect again. I also should note, when I tried to start it last night, there was a loud buzzing sound maybe like a relay when I was pressing the start button a number of times.
    #27 robl45, Aug 23, 2018
  8. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    So, you have some warning lights on your dash?
    Personally, I don’t think the OP problems had anything to do with his 12 V battery. It a shame he never came back to resolve the thread with the solution. But presumably the dealer fixed it.
    What “scanning stuff ” do you have at your disposal?
  9. robl45
    robl45 Member
    137
    I believe op had same problem I do. It was probably the inverter pump blew the fuse.
  10. legitxeris
    legitxeris New Member
    san leandro
    Did the dealer diagnose and fix the problem?
    I have the same problem!
    Dec 2017: While driving 70mph on the highway, I ran over a bump and various lights came on the dashboard. I was scared so I pulled over on the highway. After turning the car off and on, I was unable to switch gears. Pretty sure engine light and red triangle was on. Took it to a garage, they hired an electrician to check it out. They charged the battery and told me the cable was not secure.
    August 2018: at 7am, Car would not change gear. Red triangle and Engine light and a couple other lights came on. Took a taxi to school and came back in 2 hours, then everything seemed fine. I drove it to dealership and they told me 18 codes were diagnosed. They charged the battery and drove it for over 3 hrs. and there was no problem. They said it was probably the catalytic converter, so I replaced it.
    October 2018: Car would not change gear. Red triangle and Engine light and a couple other lights came on. This time, I was able to get the car going after 20 minutes. Unfortunately, as I was driving 50mph for one minute on the highway, car seemed to have gone into neutral. I could not accelerate at all so I pulled over Same problem, I cannot change gear. Brought it to dealership again and they are still unsure what to do. They said the problem has to occur while their machine is plugged into it. They will charge the battery and try driving it around. I told them my battery is probably leaking.
    Is this dealership incompetent or is it really that hard to diagnose the problem?
    What do you think the problem is?
    What should I do?
    Thank you in advance,
    Kyle
  11. robl45
    robl45 Member
    137
    You likely do not have the same problem. The car would not start at all if the inverter pump was bad which was my case and likely the case with this op.
  12. bisco
    51,968
    you probably need a new 12 volt battery. how many miles on her?
  13. legitxeris
    san leandro
    Only 80k miles. Dealer said battery is not the problem. Previously, in 2017, this same thing happened and another auto shop told me battery was tested 3 times and was good.
    My gear lights were flashing too. Toward the end, my gear lights were slightly dimmer (this sounds like a battery issue to me).
    I am wondering if the battery is leaking/discharging somewhere. I asked dealership to make sure the cables are all secure and they double checked it.
  14. bisco
    51,968
    dealer sounds clueless. take it to arts or luscious
  15. MD Afzal-Hushain Ahmed
    London
    Hi there i bought a 2008 prius wich when driving on the motor way at first the engine managment light, also the vsc and (!) Came on
    . . We drove to our destination amd just the red triangle and engine mangement light is only on...
    Prior to that in the morning after the car was ready it wouldnt switch out of 'p' to D
  16. MD Afzal-Hushain Ahmed
    London
  17. Cassandra Lace Penner
    Arizona
    I was having the same issue,jumped my car and it fixed the issue immediately after which I drove in a battery charging manner.
  18. Sara T
    Sara T New Member
    Hampton florida
    Having the same issue. I wish OP would have shared what he found out.
    Anyone else have solutions. Went through a bunch of fuses, might do a double check before I take it for diagnostics.
  19. Austre
    Austre Junior Member
    Hi Max,
    I'm going thru the same problem. Did you find the fix for this problem????
  20. dolj
    dolj Senior Member
    8,450
    4,291
    MAXsandwich was last seen on PriusCHAT on Jun 14, 2014, so I would hold your breath waiting for an answer from her.
    How about you start your own thread with information about your specific problem and what you have tried already?
    I presume you have removed the terminal clamps from the 12 V battery, ensured both the terminal and clamps are (shiny) clean, backed the clamp bolts off and pried the clamps open, reseated the clamps right at the bottom of the terminal, and snugged them up nice and (goldilocks) tight?
    While the terminal clamps were off the battery, did you use your voltmeter to measure the sitting voltage of the battery as it is right now?
