Prius WON'T START the first try..
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pepelily, Feb 3, 2013.
  1. Pepelily
    Pepelily Junior Member
    34
    Georgia
    I have prius 2009 44k....this is the second time in 3..4 months that when i press brake and push start button..All lights in the car turn on as usual and warning light stays on as well (no normal) ...screen on dash does NOT turn on (touch screen) ..and of curse car is not ready...just lights on (dash ones)...so i have to push power 2 more time to shut it off and start over..then car performs normally...What could it be???thanks for any help
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Following
    52,731
    brake switch needs adjusting or press harder on brake. otherwise, 12 volt battery?
  4. Pepelily
    34
    Georgia
    Thanks...i think i didn't press it hard enough. ..in case it needs adjustment do i need to go to toyota dealer? ?. Thanks
  5. bisco
    52,731
    i've never done it. if you want to try it yourself, search here, there may be previous threads on it. otherwise, any competant mechanic should be able to do it. all the best!
  6. Pepelily
    34
    Georgia
    NICE Thanks
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the Gen II maint. Troubleshooting forum from the Prius v forums.
  8. Patrick Wong
    18,210
    6,517
    It is not necessary for you to shut the car off. Just press on the brake pedal HARD, and press the POWER button once to get the car READY.
  9. Pepelily
    34
    Georgia
    Thanks a lot..i think Its working
    Thanks for your time
