Prius won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Enoblk, May 1, 2016.
  1. Enoblk
    Enoblk Junior Member
    36
    Oregon
    I wasn't using a voltmeter, I was using a snap-on battery tester
  2. Enoblk
    36
    Oregon
    Went out to the car this morning and it had the same issue again unplugged the steering control module under the dash and it started up again, not sure how to permanently fix this
    52,758
    is this something tech stream diagnostics can help with?
  4. Enoblk
    36
    Oregon
    Idk I guess I could check, no warning lights though
  5. bisco
    52,758
    could the other end of the wiring harness from the ecu be loose or a short somewhere that changes when you unplug and plug into the ecu?
  6. Enoblk
    36
    Oregon
    If it continues and I can't figure out the cause, I'm just going to add a toggle switch to whatever wire in the harness is causing the issue
