prius wont switch engine on
Discussion in 'Gen 2 Prius Main Forum' started by alikhan18, Sep 5, 2016.
  1. alikhan18
    alikhan18 Junior Member
    31
    Pakistan
    so its new news... patrick got these codes please advise
  2. alikhan18
    31
    Pakistan
    the one with only 2 codes r when he tried to erase n these were left
  3. Patrick Wong
    18,210
    6,526
    DTC P0A1D means that the hybrid vehicle ECU has failed. That is located behind the glove compartment (along with the engine ECU). A new HV ECU will be fairly expensive but used ECUs are very inexpensive due to the low failure rate, at least in the US.
  4. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Before you go and spend a lot of money on parts, please unplug the power connector to the AUX (12 volt) battery. This will clear everything in the ECU allowing connection to other computer modules. Once my 12 volt battery discharged because I had left the headlights on. I had to clear the faults cause by that before it would go into drive. (It would start)
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    One possibility is the inverter cooling pump may have seized and taken out the fuse, check the AM2 fuse.
  6. alikhan18
    31
    Pakistan
    latest update... because my gear box had almost no cvt oil in it ... something broke in it hence it was having jerks n couldnt start. nw i got used transmission n getting it fitted n having my fingers crossed so tht it should be the only problem. ll ppst final result soon
  7. bisco
    52,863
    did it leak out, or came that way from the factory?
  8. alikhan18
    31
    Pakistan
    hmmm no they say axle seal was damaged so it leaked from there.
    i ve doubt tht is there no sensor or check light for low transmission oil?????
  9. bisco
    52,863
    good point, that would be surprising. or at least an overheating code.
  10. Car-ingwithkids
    Car-ingwithkids New Member
    Seattle
    Hi my question is after all that and all those codes what did they do to actually fix it?
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Hi-
    Your tagging on a 3 year old thread your better off posting a new thread explaining your issue. The thread you question ended up being a trans with no trans fluid which is very rare.
    Failed hybrid battery is very common now given the age of the car. You have codes launched in your car they need to be decoded as the car will tell you exactly what its unhappy about. But usually if you have a red triangle on the dash (master caution alarm car very unhappy) and on the mfd the screen over the radio if that has a little icon like a car in the upper left corner (like the previous thread) we call it the turtle that usually means the hybrid battery has failed in one way or the other. I think the thread you tagged that guy had multiple issues.
    Which is probably why he never returned.
    Skibob likes this.
