Prius wouldn't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by avoice217, Sep 29, 2022.
  1. avoice217
    avoice217 Member
    180
    22
    So yesterday I went to go get groceries and when I tried to turn it off, it immediately turned back on (which at first I didn't think anything about) & then I pressed the button again. When I got back, I tried to turn it on & the display panel wouldn't hit up. I had to wait I'd say an additional 2-3 minutes for the car to turn back on. I currently drive an 09 Prius. I was able to take it to my local Autozone where they checked the battery & the battery turned out to be fine. I know that Prius cars don't have alternators, but what about starters like regular vehicles? If anything, I'm just trying to diagnose the reason for why it suddenly decided to not start?
    52,671
    probably a bad combo meter
    52,671
    call these guys, the slash is a link> (/)
  4. PriusCamper
    PriusCamper Senior Member
    13,324
    5,392
    Pacific Northwest, USA
    If you have a friend or family member that's good at soldering. You simply pull the combo meter (aka: speedometer) out of the dash and replace the capacitor on the board. Very easy fix! Also this problem usually is intermittent at first, so it's easy to procrastinate on.
  5. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    If it’s intermittent, just do this, takes one minute
  6. avoice217
    avoice217 Member
    180
    22
    Hey all so I just wanted to give an update: it has nothing to do with the dash. However, I've been carrying this portable jump starter from Harbor Freight with the car in case the same thing would happen & I'm thankful I did. The car wouldn't start after I left college & jumped it there & then around an hour later had to jump it again at the grocery store. The only thing I can think of that's causing it is the spark plugs (they haven't been replaced yet, but that's just a guess).
  7. Another
    1,819
    520
    Naples, Florida
    How do you know that?
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,010
    NJ-USA
    Problems with the spark plugs will cause the engine to misfire (run "roughly" and turn on the "check engine" light). It won't affect powering up the car.
    What you are describing matches a common failure mode for the the Combination Meter (the instrument cluster or "speedo"). There is a bad electronic component (capacitor) on the circuit board that can disrupt function of a computer processor in the CM.
    The car needs the CM to work in order to power on and off correctly.
    If using a booster allows you to power up, you should measure the voltage of the 12V battery before you use it. A Prius doesn't need lots of power from the 12V to turn on (all the heavy lifting of starting the gasoline engine is performed by the High Voltage system). (you said the 12V tested "ok")
    A healthy 12V reads 12.6-12.8V with the ignition OFF. Most of the time, it can still power up at 11.5-12.0V (but the battery is weak and should be charged and tested).
    My point is that when the CM is having problems, changing the voltage of the 12V system up or down slightly can sometimes make the CM (and the car) turn on. This problem isn't going to fix itself.
  9. avoice217
    avoice217 Member
    180
    22
    Ok so based on the video when it comes to replacing the combo meter, I just have to be patient when it comes to removing most of the covers on the dash in order to get at the combo meter. After that, the combo meter seems very straight forward. However, since the car isn't giving off any immediate check engine light issues, the fix on this will have to wait (I have a truck with a check engine light issue that unfortunately takes priority in this situation). When I do get the part for this (thankfully my state has a company that deals specifically with this), ill definitely update you guys. I do appreciate your patience working with me on this.
  10. bisco
    52,671
    if a jump pack works, it's the battery
  11. bisco
    52,671
    a jump pack cannot overcome a bad combo meter
  12. ChapmanF
    18,874
    Is this the PriusChat version of rock, paper, scissors?
  13. bisco
    52,671
    hopscotch
  14. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    From my reading of many reports related to this issue, it seems that a CM with a failing capacitor, a higher 12 V voltage makes the CM fail-to-start problem occur more often. I think that is why all the 'secret' workarounds appear to work (at least initially) as they, in essence, lower the 12 V voltage. Good for getting the CM to work. Very bad for the 12 V battery in the long run.
  15. mr_guy_mann
    4,109
    2,010
    NJ-USA
    Well, Gen2's don't have EGR coolers or head gasket problems, so we have to do something to stay occupied.
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I'll agree with that. Causing an up or down transient, even if minor, at the CM power source voltage can be enough to "jog" the circuit into working. Kind of like thumping an old style ICE starter motor when they start to fail. The mechanical thump agitates the motor brushes enough so that they make contact again. On the Gen 2, the electrical "thump" of screwing with a bunch of switches and buttons provides the agitation. AND, just like the old starter motors, that 'thump' eventually just doesn't work any longer.
  17. avoice217
    avoice217 Member
    180
    22
    So after doing more research, one of the symptoms that I've noticed is the back hatch staying locked while the other doors are unlocked. Thankfully the Texas Hybrid company does repair these and so ill have to purchase a refurb & once I remove my current board then ill send it back to them & they'll refund me the $75 shipping fee.
  18. dolj
    dolj Senior Member
    8,631
    4,385
    Just to clarify, the $75 is a core charge, not a shipping fee. They refund the core charge when you return your defective core.
  19. Another
    1,819
    520
    Naples, Florida
    The rear hatch problem may not be related to the CM. In my case a few months ago I noticed was a similar and more frequent problem with my 2007 rear hatch. As it turned out the actuator had gone bad. Changing it out is a five minute exercise with one cable clip and three bolts. A new OEM one is very expensive $300 and no aftermarket options exist for the rear hatch, although there are many for the other door actuators. Used ones on eBay are $70 or so. I was able to get one for the rear hatch from a junk yard for $12 or so. I was reluctant to buy one since I figured it might be bad too. As it turns out that one from the junk yard was like new probably had been changed previously recently by dealer.
  20. dolj
    dolj Senior Member
    8,631
    4,385
    Whether it is the CM or the latch actuator is quite easy to distinguish. If it is the CM, it only does not unlatch the rear hatch when the CM is dark. When the CM is running then the door unlatches as normal. If the actuator has failed then the door never unlatches.
    The rear hatch actuator has a very low failure rate so I wouldn't have any qualms about using a used one. Another interesting observation is that a 10 or 12-year-old part will look brand new. I guess it is pretty sealed up there in the back.
