Prius ZVW30R 2009 Fuel filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tiff Sky, Jun 30, 2015.
  1. Tiff Sky
    Tiff Sky New Member
    Australia
    Hey guys
    I'm from Australia. My car is a 2009 ZVW30R Prius. It's currently on 83700km . I brought it to the mechanic last week , he changed the oil, air and fuel filter. However , these couple of days, the malfunction indicator light is on.
    But the light comes on in yellow without the word CHECK. I took it to the mechanic again, he says he must have put in the wrong type of toyota fuel filter. Do any one know much about fuel filter for 2009 ZVW30R Prius ? Does it need to be replaced?
  2. myPriusAcct
    myPriusAcct Junior Member
    29
    17
    49,469
    welcome to priuschat! there's no reason to change the fuel filter unless you're having problems. have someone with a toyota scanner read the trouble codes. all the best.(y)
  4. Mendel Leisk
    38,718
    ^ I think you're right. Unfortunately the Aussie maintenance schedule calls for replacement. Wonder why: iffy gas?
    I'd be inclined to not do it, anyway. It's nuts to pull the car half apart and replace an expensive, more-n-likely perfect condition component.
  5. bisco
    49,469
    argh! i always get mixed up by toyota's international maint. changes.:mad:
  6. Emcguy
    Emcguy Member
    176
    29
    Australia
    I noticed it in the Aussie 5 year 100,000km service too. When is it recommended in the Canadian/American versions?
  7. bisco
    49,469
    nothing in usa, i guess you just wait until it craps out.(n) but you read very little here about clogged fuel filters.
  8. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Maybe if you buy from a station with a rusty tank, but that problem's rarer than it used to be.
    The original filter in my Mazda clogged at about 260K miles. Its replacement went farther than that without ever clogging.
    When I was small, my family's trip to my great-grandfather's funeral was interrupted by our car starting to cough and sputter badly. It sputtered into a service station (Remember those?!), where the mechanic diagnosed a plugged fuel line and managed to blow an unfortunate insect out of the plumbing. Back then, cars had no fuel filter, although some had a glass "sediment bulb" in which stray rust or dirt particles were supposed to settle en route to the carburetor.
  9. Mendel Leisk
    38,718
    No mention in the Canadian schedule.
