PriusC or Gen3?
Discussion in 'Newbie Forum' started by James Godish, Oct 10, 2016.
  1. James Godish
    James Godish New Member
    Central New Jersey
    Hi.
    My old 1996 Subaru just finally said enough and I'm thinking of buying a Prius. There is a used Prius C (31k miles) that is for sale close to my home for 13,000 (closer to 14,000 with sales tax and fees) that's just in my budget.
    I'm going to test drive tomorrow.
    Do you think it's wise to hold off buying the Prius C and go with a gen3 instead, since that battery has been around longer?
    Is the gen3 that much bigger than the PriusC?
    The gen3's around here have a bit more miles on it for that same price.
    Thanks for your help.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I would go with the gen3. Much more cargo space, smoother ride, bigger more powerful engine, and I've read from owners that it gets the same fuel economy if not better.
    James Godish likes this.
  3. James Godish
    Central New Jersey
    Thanks Aaron. Seems like for that price, I'm looking around a 2010 @ 100,000 miles or so, but I'll keep looking....
    49,520
    welcome! c battery is well tested, so don't concern yourself with that. it's going to have more to do with highway vs local driving, and interior volume. drive them both and get a feel for comfort. the lift back will return a few more mpg on the highway, and vice versa. i would try not to make price part of the equation if possible. all the best!(y)
  5. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    For that price range you can do much newer. I bought a 2012 liftback in April for 12k and it had 42 thousand miles, and still under warranty. Trust me for that type of money you can do much better than a 2010.
  6. bisco
    49,520
    just expand your search to the southeast, and be careful of matthew cars.
    James Godish and Aaron Vitolins like this.
  7. Aaron Vitolins
    1,612
    1,144
    Franklin TN
  8. bisco
    49,520
    i just lost a couple thousand in value, and wonder if i should sell before prime comes out and wipes out the remainder.:unsure:
  9. James Godish
    Central New Jersey
    Thanks for that. I appreciate it. Don't know much about plug-ins...but I'll research it.
  10. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    It's not really the fact it's a plug in I just wanted you to know you can get a much nicer and new car than you think!
  11. genii_rich
    genii_rich New Member
    florida
    Definitely get a gen 3. I picked up my 2014 for $15,300 with 36k miles, brand new tires, leather seats, navi, and an installed hitch with a basket. Trust me, take your time looking through the dealers or on craigslist. I found a one owner 2012 gen 3 with 67k miles for $9500. Decided last minute to get the 2014 instead even the the 2012 was a great deal. The gen 3's have more room, looker better imo, and as others said...get the same mpg if not better I believe. Also, don't be afraid to travel a few hours if you're getting a better deal. Just be sure to ask plenty of questions, ask for maintenance records, and many many pictures before making the trip out there. I was set on driving 3 hours to pick up the 2012 until i found the 2014 that I now currently own.
  12. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    If you need a smaller car to park , get the c.
    If you ever expect to use the back seats or cargo space, get the liftback.
  13. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    I thought the C had significantly less get up and go than the regular Prius. Presumably because of the smaller engine.
    To be fair, I didn't know much about Prii then; perhaps I was in economy mode and 1st half of pedal travel was all electric. ...
    But I suggest you try both in Power mode before deciding. I got the regular Prius and am please as punch with absolutely adequate space and terrific cost savings.
    I also thought the C had undersized leg room for the back seats. If anyone is going to be riding back there, I'd adjust the front seat the way you like it and have someone similarly sized to your regular rider try the back seat. For my son, that was a no go ! He's a bit tall.
    Also, for putting lumber in, etc, I measured a comfortable 9' 8" in the regular prius, although I've heard tell on this board of 10' boards in the prius with all passenger seats down, hatchback closed.
    For me, the C had too many potential annoyances to bother with, i.e. if ANY of the issues will come up sometimes...you may want to go mid sized.
    Another thought: if you're at all concerned about gas mileage, DON'T BE!
    As my thread here.... You won't save much money by hypermiling | PriusChat
    lovingly delineates, saving 5 or 10 mpg when comparing to an already 'high' number only saves you like $100 a year.
    I.e., if, for some reason the C gets 5 mpg better than the regular hatchback, that will only save you $100-130 per year.
    Yep...you really won't save much.
    (others disagree with the definition of the word 'much'. For me....$100 is no worth repeated aggravation)
    Another thought: depreciation is significantly higher in years 1 and 2 (as well as 3). Which is why I chose a 2013.
    2013 was also the mid-generation re-fresh. I don't think it had significant changes, but there were some tweaks.
    Years 3 or 4 through 7 are the traditional sweet spot for depreciation; I suspect for the Prius it's more like 3 or 4 through 10, since it lives so long with few repairs or maintenance issues.
    Hope this helps! Core dump of info, here... :)
    PNB
  14. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    Prius c 0 - 60 10.9 seconds Top Speed 102
    Prius Liftback 0 - 60 10.5 seconds Top Speed 115
    Both via Car and Driver
  15. PriusNeckBeard
    376
    211
    Cincinnati
    Their numbers probably address this, I suppose ..but I care more about 0-->20, 40-->46, stuff like that. It's pulling out into traffic and giving it a little juice while passing that matter. Just a thought
  16. killertofu88
    killertofu88 Junior Member
    32
    Boston
    I was originally considering a C, but then I tested it going up a hill and on the highway. Definite nope for me. I don't need a high performance vehicle, but I need something I don't need to hold the gas all the way down just to hit appropriate speeds.
  17. orenji
    orenji Senior Member
    5,884
    3,486
    As an owner of a 2010 Prius Gen III and a 2012 PriusC, you need to ask yourself what do you plan to be doing with this car, if its mostly you driving alone or one passenger then the C has plenty of space and power to keep up with traffic. If you have kids or additional passengers who ride with you then you should get the Gen III, as it has much more space in the back seat area as well as in the trunk. The C feels sportier and handles slightly better then the Gen III. But the Gen III does have more power and gets slightly less MPG then the C. I average 55 MPG in the C and about 45 MPG in the Gen III. The C will be newer, and I believe N.J. is a CARB state so your warranty on the batteries will be a few years longer then on an older Gen III. Make sure you see the service records on the car you consider buying. Oil should be changed at 10,000 miles if not sooner.
    #17 orenji, Oct 12, 2016
  18. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    If the car is CARB warranty eligible (originally purchased in CARB state and being currently purchased in CARB state), then the Gen III has the advantage of 10yr/150k mile warranty on hybrid components, whereas the PriusC will only carry 8yr/100k mile warranty for the hybrid components.
  19. orenji
    5,884
    3,486
    It all depends on the age of the vehicles and mileage as these are used vehicles.....
