PriusChat Earth Day Chat
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Apr 21, 2009.
  1. toronado455
    toronado455 Member
    179
    22
    Southern California
    Doh! I didn't realize that. :)
    All the more reason ditch them though. If they require a mod to prevent rubbing, they shouldn't be using them to begin with. They need to engineer a rim/tire upgrade that works with the standard steering setup (to save cost), and doesn't invoke a weight penalty. Maybe that's the challenge to which Doug was referring.
  2. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I thought I saw a spec sheet somewhere on this forum that showed the tread width on the 17" rim/tires to be essentially the same as the 15"ers. I will look for it and post a link if I find it.
    Roy
  3. Tideland Prius
    16,670
    tread width for the 17 is 215mm. Tread width for the 15 is 195mm.
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    At the risk of being accused of double posting, I would really love to get clarification from PriusTeam on how trivial it will be to change between 15 and 17 wheels on either the IV or the V, preferably before I have to decide to pull the trigger on my pre-order! :D
  5. Tideland Prius
    16,670
    If I had to guess, it's easier to downsize than upsize for reasons that HTMLSpinnr mentioned. Because the 17" alloys have a wider turning circle (due to the steering setup and to avoid the tyres from rubbing the inside wheel well), you can downsize and none of the settings will affect the drive (other than you won't get the same turning circle as the stock 15").
    However, if you had to go the other way, you might have to modify the steering rack so that the larger tyres won't rub as they might with the stock 15" setup.
    Hope that makes sense.
  6. toronado455
    toronado455 Member
    179
    22
    Southern California
    Either that or just don't ever turn the wheel all the way to the extreme left or right. :D
    If the only time the wheel rubs is when the steering is turned fully to the left or right extremes (which is what it sounds like from the fact that the mods for the 17" are to limit the turning circle), you're only going to encounter that in tight parking situations and you can just train yourself to back off the bump stops a little after you hit them before you start moving. A lot cheaper solution, and it would allow you to have the tighter turning circle should you decide you don't like the 17" and switch to the 15" later.
  7. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    It also occurred to me later that the AT package could also be affected, though I'm not sure how. Even with the same total wheel circumference, I wonder if the distance maintenance and collision avoidance calculations, and stopping distance, could be affected.
  8. royrose
    1,389
    953
    Foot of Pikes Peak
    I misread the data. It was "Tread width (front/rear) 60.0/59.8 (15-inch tires), 59.6/59.4 (17-inch tires)"
    Obviously, they were talking about total track width not tread of each tire.
    Roy
  9. Tideland Prius
    16,670
