PriusChat is on its way to Detroit!
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Jan 10, 2009.
  1. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I don't know about you, but I was planning to be well dressed. Or at least clothed. :rolleyes:
  2. eclectcmoi
    eclectcmoi Muffinologist
    6,764
    17
    Lakewood, CA
    Sounds like another great photo opportunity! Hee!
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've got my "date" clothes on ;-)
  5. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Questions for you lucky folks who are there:
    1. Telescoping steering wheel, yes or no?
    2. It that a USB port I see in one of those pics?
    3. The Nav-equipped system, where do you load CDs? I see there's an Open button.
    4. The non-Nav version, there's a button called Type, what's that? And what exactly does the Text button do?
    5. The 12V plug's cap says 12V/120W. What does that mean?
    6. When you slide back the console cover, you don't have to flip it up to put your cup in, right?
    7. Looks like the Aux in and 12V in the console are still there, correct?
    8. Does the display show info such as Engine Temp or RPM?
    9. How many adjustments for driver seat? Manual or electrical?
  6. Patrick Wong
    18,210
    6,510
    My notes from tonight:
    The product brochure, pricing, and New Car Features Manual will not be available until the car is released in May.
    The steering wheel telescopes and tilts.
    The driver's seat can adjust up and down, forward and backward, and the seatback tilt angle. Some models have lumbar support adjustable via pushbutton.
    The inverter is much smaller than on 2G. The traction battery also appears smaller but has the same capacity, 201.6V nominal, 28 modules. The 12V battery is the same as 2G.
    The inverter converts 201.6V to 650V, so this should be more efficient than the current design. The motor generators are also smaller and presumably more efficient.
    The point of the increased displacement of the 1.8L engine is to allow the ICE to rev slower at freeway speeds which results in the improved mpg. City mpg should also be improved. Contrary to earlier info, 1.8L is the worldwide Prius engine.
    Recommended oil viscosity is 0W-20 and 5W-20.
    The 2G North America coolant heat recovery system is now gone. It is replaced by the EGR heat recovery system. The fuel tank bladder is gone.
    The rear brakes are disc, not drum.
    On display were three Prius models. One was base, one had the sunroof and solar panel, and the other had the LED headlights and headlight washers, and the intelligent parking assist.
    The main relay/fuse box still resides next to the inverter and the dedicated positive jump start terminal still lives there.
    The engine ECU lives next to the main relay/fuse box.
    The cabin air filter seems much more substantial than Classic and 2G. A couple of ECUs are located in the vicinity, one is probably the hybrid vehicle ECU; not sure what the other is.
    The battery ECU still is located in the battery case but the interlock is now on the RH (passenger) side of the battery case. I suppose the battery cables probably run on the RH side of the car now, vs. LH side for Classic and 2G.
    The throttle plate still exists.
    There are two cupholders in the front and two in the rear. The front cupholders are inline, where one has a cover that flips up while the other is revealed when you slide the center console cover backwards. No need to flip that center console cover, it just slides.
    The rear cupholders are side by side, located in the rear seatback which flips down to occupy the space where a middle passenger might otherwise sit.
    I think the 2010 Prius is a winner. The sales target is 180K units; in a normal year I think it will do better than that. Given a weak economy, we'll see.
    16" and 17" wheels were on the display models. Bridgestone and Michelin tires were installed. NO Goodyear Integrity tires.
    An outstanding reception hosted tonight by TMS USA and Prius Team.
  7. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Some supplemental observations:
    1. There will not be a Touring Edition, nor an option for a beefed up or tuned suspension.
    2. Looking under the hood, it doesn't look like there's room for a strut tower brace.
    3. The optional 17" wheels are nice looking. No covers or trim rings of any sort. I think the tires on them were 215/45/17. I think I saw two different tires on them - one made by Michelin and another by Bridgestone. Word is that the final tire hasn't been determined yet.
    4. The standard 15" wheels are ugly. They have full covers. When the covers were removed, the wheels were even uglier. I think the tires on them were 195 width. Don't remember the aspect ratio. I think the brand tire I saw on them were Bridgestone.
    5. The front seats were noticeably more comfortable with more lumbar support than the Gen II. And more importantly, in addition to the fuller range of adjustments (height, lumbar, tilt), the front seats slide around 3 or 4 inches further back than the Gen II, i.e., they slide as far back as a "normal" car. I always thought it weird that the rearmost range of the Gen II seats seemed about 3 or 4 inches shorter than any car of any size I can remember. With this longer rearmost track, plus the seat adjustments, plus the telescoping steering wheel, I think the driver's seat and driving position will be much more comfortable for many more people.
  8. darelldd
    6,059
    389
    Northern CA
    You do what you gotta do, and I'll do what I've gotta do.
    And you were a knock-out. I was out there beating the babes away.
    tilt and telescope, yes.
    No clue. I must have missed it.
    The whole face tilts away, and the disk is loaded behind the display.
    No clue.
    That you shouldn't use it to power a device that draws more than 120W.
    No, and that is a REALLY slick feature. It means you can use the inside cup holder and still use the lid as an arm rest. You can then tilt it up to get inside at any point.
    From what I could tell. Had trouble getting my flashlight out of my pocket when I needed it.
    Not that I saw. Tons of info taked out of the MFD and put up on the dash. But nothing like that - that would scare the poor drivers to have that info!
    Manual (like a jack) up and down. Electric lumbar.
  9. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    PATRICK - cheers brother. if the new engine requires the 0-20 or the 5-20, can't we use that on the G2's??
  10. zenMachine
    3,355
    300
    Thanks for the details, guys. Much appreciated.
    Did anyone notice whether the rear hatch can be opened from the outside if there's no power? i.e. dead battery. If not, does it still require user to perform Copperfield contortions to open from the inside???
  11. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Well, I did notice that there is TWO hand holes for pulling down the hatch... one on each side! Now Lefties have equal rights! :)
  12. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    You guys are having too much fun out there!
    I'll save my pennies & check out the Philadelphia auto Show in 2 weeks.
    (or
    Meantime
  13. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
  14. zenMachine
    3,355
    300
    Did anyone get a chance to crank up the stereo?
    If the Nav disk is now behind the screen, does that mean the space underneath the driver's seat is freed up for things like a subwoofer?
    And directly below the Power start button, isn't that a USB port?
    BTW, I really don't like the lack of reverse camera and BT on non-Nav G3s. To me that's a significant step backward; those are my two most used features day in day out, whereas I use my GPS only maybe 20% of the time.
    Not that any of this matters to me since I'm waiting for a hybrid minivan anyhow.
  15. HTMLSpinnr
    5,341
    920
    251
    Yes, there were a few users who brought CD's to test the stereo. It does sound better, but we have no specs specifically. Bottom end sounds somewhat better than the current. They also ditched the useless 9th speaker up above the MDF location. There is still no subwoofer.
    No. NAV ECU still resides under the left seat, the DVD is the only thing relocated. There was an open plug on the ECU that I was curious about.
    No - that's the parking assist button.
    You need an MFD for the bluetooth function, and the MFD is not included anymore w/o NAV.
    Then quit you're griping :lol:
    I'd love one too, but Toyota is concerned that one of the existing hybrid mini-vans is too small for the US as it's only seats two across in 3 rows. They're not sure how Americans would handle a Skinny-van. I'd expect to see something more along the lines of the Highlander (more likely) or Camry (my speculation, but preferred) drive train showing up in a Sienna.
  16. HTMLSpinnr
    5,341
    920
    251
    Ha ha... Toyota definitely brought the car-show models along w/ the cars. They smiled great, but I'm not sure they were able to answer as many questions as the on-site product specialist who we rudely interrupted w/ more gawking and gazing. Poor girl...
  17. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Did you see the Ford Fusion Hybrid ? Was it only up on a turn-table, or was it on the ground for you to sit in? Any news on the Fusion Hybrid?
    Thank you. :)
    I hope you are going to have an entire thread or Flickr album dedicated to "an overview of the entire Detroit Auto Show." Perhaps a list of all new hybrids, EVs, and other green vehicles.
  18. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Gee Dave, that's a bit insulting! I thought Pat's effort was top notch! Good symmetry has to be a bit hard to do on that scale. Add to that the poor man is 12 hours off schedule and just off a REALLY long flight.
    5 stars to Pat and his artistic effort. And unlike regular graffiti 'artists', Pat's work is not permanent, no harm done.
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I had a hard time sleeping with Pat out there stomping around under my window.
    Tom
  20. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    Doc Willy put the nav/JBL through it paces, check his thread in the Audio section. Below the Power button is either a blank or the IPA button(if equipped). The base model car had the JBL system with BT and no NAV system.
