PriusPrimeAdvance GPS Locator connection
Discussion in 'Prime Main Forum (2017-2022)' started by TonyStark333, May 6, 2019.
  1. TonyStark333
    TonyStark333 New Member
    Penang
    Guys, i have a gps locator installed in mine priusprime and i could not recall how to connect to it. its installed as standard part to the advance vertwo version. Prototype model. Could the prius toyota team inform me how to reconnect to the gps locator?
    Thanks
    TonyStark
    Piseries333
  2. Tideland Prius
    16,634
    A Prius Prime isn't available in Malaysia.... o_O
  3. TonyStark333
    Penang
    Yes its not widely sold in malaysia as they could not afford the car yet and there is little ev charging stations around.
    However i shipped a prototype prime to penang on my name as testing vehicle for on the road test.
  4. Tideland Prius
    16,634
    Ohh ok. You're doing a trial run. I see.
    Prototype may not be the correct word lol (especially since the vehicle itself has been around for 2 years in other parts of the world). But what you mean, is that you have a car that is set up for Malaysia roads and you're doing a trial run.
  5. TonyStark333
    Penang
    It is still a prototype, as in the parts of the car is brand new setting to test the conditions to get better mpge and battery lifetime extensions.
    the suspensions are the same double wish bone.
    Tideland Prius likes this.
  6. Tideland Prius
    16,634
    Cool.
    Well hopefully someone here has an answer for you.
  7. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    I think you connect to your GPS location on the built in map or on the Entune app on your mobile device. Can you use the Entune app to bring up any vehicle information or settings (AC, charging, location)? Canada does not get to use these features as I'm guessing Toyota has not made arrangements with cellular companies to transmit data from Prius to Entune app and vice versa. Does Entune app work in Malaysia?
  8. Tideland Prius
    16,634
    There's two types of GPS chip that he could be talking about - either the navigation or the Safety Connect system. I suspect he's talking about Safety Connect (which won't work in Malaysia so he needs to install his own GPS tracker if he needs it for fleet or trial tracking purposes)
