Private equity and LeafFilter scam
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Apr 28, 2026.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,604
    Taylors, SC
  2. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    Your video isn't viewable...
  3. Brian1954
    Brian1954 Senior Member
    2,691
    1,076
    South Central PA, USA
    I could view it.
    52,863
    I've never trusted gutter guards
  5. Georgina Rudkus
    3,576
    2,604
    Taylors, SC
    I use the cheap steel black coated ones from Home Depot with 1/4 inch mesh.
    All the trees in my house are oaks, and t h eyes work just fine.
    Only roof shingle granules land on the bottom of the gutters and do little to restrict the flow of water.
    This would not work with pine needles.
  6. BiomedO1
    BiomedO1 Senior Member
    4,630
    2,427
    Left Coast
    I've tried most gutter guard systems and they usually work for a few seasons, before they start clogging up in their own way. I've never paid anyone to install one of those systems; because I'm too cheap and don't really believe them to begin with. I've installed the wire mesh ones from home depot. That took 3 years to clog up, so I removed it. It's just simpler to just move a step ladder to the down spout, reach-in and remove the little beaver dam. The small branches that caused the clog in the first place; floats and spills out over the side of my gutters. My gutters are large and deep enough to flush all the dry leaf materials through the down spout. I only have to do that once a year, when I see my gutters overflowing. Usually during the first heavy rains.
    And I get to invest that $15K instead.......;)
  7. Mendel Leisk
    42,355
    I use a variety of methods. Sometimes just put up a ladder and scoop it out. Other times, install these on my wet/dry (on blow, usually), and have at it:
    You want to be wearing old clothes, and eye protection is a must.
    Zeppo Shanski likes this.
  8. bisco
    52,863
    or cut all the trees down and install solar
  9. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    I had generic gutter guards with slots installed. They work just fine. I have an issue with the fine mesh on the LeafFilter guards in that during heavy rains a great deal of the water will just run over the gutter onto what ever is below.
    My 2 cents.
  10. PriusCamper
    13,468
    5,437
    And that whatever is below could be the type of erosion that leads to very expensive foundation damage.
    Out here in the PNW we got huge amounts of tall trees constantly precipitating debris, as well as huge amounts of rain. I only once cleaned a roof with these type of gutters and they were clogged with tree debris and was told not to worry about it.
  11. Georgina Rudkus
    3,576
    2,604
    Taylors, SC
    The commercial says that "YOUR GUTTERS WILL NEVER CLOG."
    But the Leaf Filter screens definitely will.
  12. PriusCamper
    13,468
    5,437
    I'm sure they'd argue that they still work as though they aren't clogged even when they are clogged....
