Proactively replacing 12v
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 2, 2017.
  1. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Woops meant to say I didn't know this. @Raytheeagle is hitting 8 years on his with a battery tender. I think I'm stupid enough to challenge him for the record. :LOL:
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    It will be 8 years in my possession on August 9th:).
    I welcome the competition (y).
    mmmodem likes this.
  3. Tideland Prius
    16,670
    You bought in Aug too? Mine was picked up August 29, 2009!
  4. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Amazon for Optima designed for Prius only. $162. Cheaper than the dealer.
    iPhone ?
    #44 trentofdestiny, May 10, 2017
  5. bisco
    52,776
    i think the map is probably generally correct, but the corresponding years are more varied. if you abuse the battery, they will be shorter. if it's garaged vs outside, that might matter a lot.
  6. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    When I lived in the East Coast, batteries always died in the winter, not in the summer. That's what I remember.
  7. bisco
    52,776
    agreed. even though heat may shorten the lifespan, a weak battery freezes on a cold day.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Bzzzzz. Wrong.
    Either the battery has to be VERY weak to start with OR it has to be VERY cold for that to happen.
    As the temperature goes down, that battery CAPACITY goes down too.
    In a conventional system with a high current starter, that "load test" finds a marginal battery when it's cold......that might still work when it's warmer and the capacity recovers.
  9. bisco
    52,776
    i'm wrong because i left out an adjective? or is it an adverb.(n)
  10. markabele
    5,084
    1,782
    Nebraska
    at least he was really nice in the way he corrected you
    Raytheeagle and bisco like this.
  11. bisco
    52,776
  12. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    How reliable is using the resting voltage on the Plug-in Prius 12v battery as a predictor of when it needs to be replaced, assuming the battery has never been run down?
    If the resting voltage is reliable indicator, what voltage would then be a reasonable cutoff to determine that it's time to replace the battery?
  13. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Resting voltage only tells you state of charge or SoC at time of measurement. It has no bearing on capacity. So you could have a weak battery that would go dead if you left the door open for 5 minutes, and it would read the same voltage as a good battery if they were both fully charged.
    iPhone ?
  14. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    What would be a reasonable load test in the Plug-in Prius?
  15. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I would say one of three things: a battery charger/tester like we have at the dealer for warranty battery tests, letting the car sit without plugging in for let's say a month for example, or letting the headlights on and/or door open for a preset amount of time lets say half an hour or 15 minutes. Then checking for voltage/if the car will power up after the last two. Obviously I prefer the first option because I have access to it.
    iPhone ?
    iplug likes this.
  16. Mendel Leisk
    42,264
    Ours was built in August 2009. Languished on dealership (or dealerships?) lot till we asked them to dig it out from the back of display shed, in November 2010. Had about 10km on the odo when we took it for a test drive. OEM 12 volt battery was dead, dead, dead. They "had it running for us" when we showed up...
    Tideland Prius and Raytheeagle like this.
  17. Tideland Prius
    16,670
    More than a year?!? Wow. I remember you said it was sitting in the back but I didn't realise it was an early build. Mine was built in July 2009.
    I wonder how many 2016s are sitting on the lots (or maybe that's why they're only factory ordered)
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    The dealer nearest us has five 2015s still on the lot:(.
    I bet their 12v batteries leave something to be desired :eek:.
  19. bisco
    52,776
    i have been using the resting 12v measurement for 13 years. it is reliable if you monitor it regularly, and haven't run the battery down. if you have run the battery down, i would just replace it, it has no integrity after that.
  20. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    What resting voltage are you getting and what would you consider the cutoff voltage for time to replace?
