Problem after egr cooler cleaning.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nathenvan, Oct 11, 2021.
  1. amarino
    amarino Active Member
    144
    105
    99
    Maybe just need to let it do the Idle relearning for the engine computer or Initialization? See attachment.
    mjoo likes this.
  2. Mendel Leisk
    42,332
    Probably not OEM? OEM through dealership parts dept is likely under $10 USD, and a safer bet, my 2 cents.
    QuarterMileAAT likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Are you sure all the connections in the OCC installation are air/vacuum tight?
    I used thread sealant (Rectorseal TruBlu) and hose clamps on all fittings/connections, and I put an o-ring under the dipstick on the OCC.
    A vacuum leak will cause rough running and affect performance.
    Raytheeagle and Paul E. Highway like this.
  4. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    deleted
  5. Mendel Leisk
    42,332
    With fuel lines pushing onto properly sized barb-connectors I think you can skip clamps, they can actually be detrimental to the hose ends, especially the simple screw types.
    Testing for air-tightness would be good if you can. I've got a piston style fluid transfer syringe:
    Plus some T-connections and vacuum check valves:
    which I can arrange (with some vacuum tubing) so I can either apply-and-hold vacuum or pressure (depending on how I orient the check valves).
    Maybe next time I've got the cans out of the car I'll test.
    Addendum:
    The whole setup, currently set up for vacuum:
    See from the gauge I can pull 20 inches. Not fantastic, but good enough for testing integrity of seals.
    #25 Mendel Leisk, Oct 13, 2021
    mjoo and xliderider like this.
  6. nathenvan
    nathenvan Junior Member
    52
    16
    Delaware
    Thanks for all the helps and ideas.
    I decided this morning to start taking thing apart again. I first drained some coolant and checked the seals and connections of the OCC. the output fuel line that goes from OUTPUT to the Manifold looks to be a bit kink. I rearranged it and straighten it out. I will put the air box back tomorrow and see if that what was causing the loud engine noise.
    #26 nathenvan, Oct 13, 2021
  7. nathenvan
    52
    16
    Delaware
    I disconnected the negative from the battery and left it for 20 mins. The problem is still there.
  8. amarino
    144
    105
    99
    Try reading the attachment on my post. It says:
    "NOTICE: Engine learned values cannot be reset by disconnecting the auxiliary battery negative (-) terminal or removing the EFI MAIN and ETCS fuses"
  9. nathenvan
    52
    16
    Delaware
    Yes I saw that but i don’t have tech-stream. Saw a thread that indicated unplugging the negative will reset the throttle.
  10. nathenvan
    52
    16
    Delaware
    So the car is still hesitant but a bit better after straightening out the kink hose OCC.
    I am gonna take the cooler apart on the weekend and check all the placement of gaskets.
    mjoo likes this.
  11. wr69
    wr69 Member
    143
    79
    portland, or
    a few ideas, which may or may not help:
    1. remove OCC and see if problem goes away? Some OCC on Amazon, i have heard, have the IN/OUT reversed? Maybe check that?
    Are the hoses on the OCC sturdy and dont collapse during vacuum?
    2. get veepeak OBD adapter and car scanner plus Iphone app to read any codes, which may exists, but do not throw a CEL
    3. the entire EGR to manifold circuit is a very tightly bolted on set of gear. Maybe loosen all the mounting/bracket type bolts and tight up the members (components) of the chain?
    4. There is a TSB for sticking EGR valve assembly. maybe something in the cleaning process triggered the valve to stick all of a sudden?
    5. maybe some crud got knocked loose and fell into the intake ports?
    If/when you find it, let us know. would be good to document. I'm working on EGR circuit cleaning in my 2010 as I type this up! Just paused for the evening.
  12. Mendel Leisk
    42,332
    The EGR assembly instruction in Repair Manual does talk about temporarily snugging the connecting bolts, then bolting it to the engine, then retightening, and checking for even contact. I sorta ignored it, but...
  13. nathenvan
    52
    16
    Delaware
    So I took all the spark plugs out and made sure it all tighten down correctly. Plugs 1-3 are all dirty and has carbon built up on the tips. Plug number for looks new. It looks like the car is running rich and foul up my spark plugs. Should I replace them or it is ok to reuse?
    I also took out the egr cooler and the intake manifold to make sure nothing is clog. Did a quick cleaning on both again. Opened up the egr valve made sure the spring still works properly. Putting it back on by screwing on the magnet clockwise. Should the magnet be screwed in all the the way or only lightly so? This is the step I am having doubts but can’t find any info on this. Please let me know if you have any info on this.
  14. nathenvan
    52
    16
    Delaware
    I had the valve replaced by a dealer a couple years ago. I have a veepak Bluetooth OBD somewhere. I will see if I can pull any codes from it. Thanks
  15. Mendel Leisk
    42,332
    Haven’t opened up the valve myself, but I’ve read here, that screwing it down and then reassembling, it’ll spring back slightly. @ChapmanF will maybe weigh in.
  16. ChapmanF
    19,011
    Too lazy to write it again, but try this post.
  17. nathenvan
    52
    16
    Delaware
  18. nathenvan
    52
    16
    Delaware
    So the car is still hesitant and loud at acceleration but once it gets up to about 30mph it quiet down and drives normal. The only other thing that I did was changed out my spark plugs from RockAuto. What do you guys think about these plugs?
    I am thinking about switching it out for the OEM plugs from Toyota.
  19. nathenvan
    52
    16
    Delaware
    Has anyone used these plugs from RockAuto?
  20. Mendel Leisk
    42,332
