Problem after replacing 12V battery
Discussion in 'Gen 3 Prius Technical Discussion' started by noah304, Jan 15, 2022.
  1. noah304
    noah304 Junior Member
    I recently replaced the battery in my 2012 Prius. Now the distance to empty isn't working properly. It seems to be overestimating the distance to empty by around 120 miles. I recently filled the tank in hopes this would fix the problem but it hasn't. Is there any chance this will self-correct over time or is there a fix I need to do that anyone knows about?
    Also, now I can't get the trip A and B to show average mpg of fuel consumption and speed on the instrument panel anymore. Instead it shows "Savings" which I've never seen before and don't want. Any help with these two issues would be greatly appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    13,564
    2,445
    Durham NC
    Really weird seems to me before I go messing with my gen 3 I'm going to plug up 12 volt supply or another battery whatever up at the fuse box on the red door and a ground car off and then take my battery in the trunk out there by holding everything as it is I keep hearing things like this and it's like what the hell
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,649
    6,680
    Texas Hill Country
    What country are you in?
  4. noah304
    US, in California to be more specific.
  5. bisco
    52,518
    have you checked the new battery voltage and connections?
  6. Tombukt2
    13,564
    2,445
    Durham NC
    Yeah it sounds like a bad ground or extremely low voltage 9 or 10 was this battery just bought off of shelf and dropped in the car and not even checked
