Problem after replacing the high voltage battery
Discussion in 'Gen 2 Prius Technical Discussion' started by LinuxOID, Jun 24, 2026 at 10:51 AM.
  1. LinuxOID
    LinuxOID New Member
    Russia
    2003 Prius
    Toyota prius NHW20 (JDM) 2003 year (pre-restyling)
    Hello everyone. So, I replaced the high-voltage battery with a used original one.
    I started getting errors P3140 and P3143 intermittently (I can't find any information about the second one anywhere). This all happened while driving, so I can't tell you the error codes because I reset the ELM.
    How I solve this problem: I simply remove and reinsert the orange pin... I insert it correctly, pushing it down at the end. After that, the problem goes away again after 30-50 km. Can you tell me what could be the cause? upload_2026-6-24_17-50-16.png
    I pulled the pin intentionally to provoke the error p3143 and read its subcode when I already had the TechStream in hand, but only p3140 appeared and p3143 did not.
    I disassembled the pin itself and everything is clean. I also tested the connector that connects to the pin and it's fine. The problem is most likely somewhere in the high-voltage battery, not in the inverter (which is what some people mention). I draw this conclusion because the error disappears after I remove the pin. Or am I wrong?
  2. Brian1954
    Brian1954 Senior Member
    2,600
    1,031
    South Central PA, USA
