problem can not start the car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vanne, Apr 27, 2014.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Hi there
    I accidentally have the check machine red icon on my
    Car firstly I have departure the car without close the door after I turn off the car and turn on again it appear the check engine red icon and after that a few minute my Car can't start and have long beep sound and my car timing reset to wrong and seem mess up everything now what I can do just turn the car off and can't do anything with it please help advise on these problem
    Appreciated you all for help
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    If you left the door open most likely the 12 volt battery in the back hatch area is dead. That battery is used to boot up the car. Very common failure.
    Don't turn the car on but just turn on the headlights and see how bright they are. If no lights or very dim that battery is dead. Many alternatives to the original factory battery here but not sure what you have over there. For comparison the factory battery at our dealer charges $250 for this battery plus installation.
    Do you have Smart Key System or do you need to stick the fob in the slot under the steering wheel to start the car? If no Smart Key System (SKS) that car will then use a slightly smaller battery current wise. Slightly cheaper.
    I say replace because it may be the original or very old and it is very dangerous to jump start this car. Easily cause accident by getting the polarity's wrong. If you must jump the car make sure polarity is correct to under hood front jump points and do not let the donor car run or race the motor. The donor car engine should not be on.
    Please review your owners manual for location of jump points. Under hood to the right of silver box (Inverter) inside the black plastic fuse box. Inside that box flip up red plastic cover. Thats the B+ or POSITIVE terminal. Use the bolt on the chassis right above it that holds the strut on for GROUND.
    Good Luck.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Charging the battery for 20 minutes or so is another good option.
    MUCH less likely to cause any damage......even if the leads are accidentally reversed.
    And if the battery is over 3 years old, a replacement probably is in order.
    If it is the original 12 V battery that came with the car new in 2005.......then you are lucky that it lasted this long and a replacement is definitely required now.
  4. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    dear all, thank you very much and appreciated for help anyways my 12v battery is still work normal
    i hope nothing seriously then that
  5. Easy Rider
    982
    210
    N. Central Florida
    How do you KNOW that the 12V is working normally ??
    The odds are GREAT that it is NOT.
    kenoarto likes this.
  6. bisco
    52,431
    have you checked the fusses? also, your oil level may be low.
  7. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    normally means the car isn't starting!
  8. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Now my car sometime start and sometime can't
    When I press power button it not start and engine check icon appearing and flashing like sos sign and the power button lighting up and off and rapidly reapeat
    And I wait about 2mn and I turn off smart key and insert
    Key to fob it start normal and I don't know for suure just
    Keep the care about 10h it may happens again
    What should I do ?
  9. kenoarto
    398
    Chicago, IL
    how old is the 12v battery?
  10. bisco
    52,431
    replace the fob battery.
  11. Patrick Wong
    18,210
    6,514
    1. Replace the fob battery now (CR2032)
    2. Replace the 12V battery if (1) does not help
  12. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Maybe around 3 year I thought cos since I bought the
    Car second hand from USA is about 2 year already
  13. bisco
    52,431
    have you checked the tyre pressure? many of us run at 42/40.
  14. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    when it error it give me the message " Caution : The transmission P lock mechanism is abnormal. Park your car on a flat surface, and fully apply the hand brake.
    what dose it mean problem about exactly ?
  15. dolj
    dolj Senior Member
    8,580
    4,357
    Wellington, New Zealand
    You have said the 12V battery is still working normally, but how have you concluded that? What testing did you do to arrive at this conclusion?
    Just to be sure, can you run the testing in this post: Weird stuff happening? MPGs dropping? Test The Battery, and report the three voltages back to us. In addition when you are in IG-ON mode put your headlights on full beam and report the time it takes for the voltage to drop below 11.0V. If the voltage does not drop below 11.0V within 2 minutes, just report what the voltage was at the 2 minute mark.
    The voltages we want to see are:
    1) ACC mode:
    2) IG-ON mode:
    3) Time taken to reach 11.0V: or Voltage at 2 min mark:
    4) READY mode:
    Thanks and hope that helps.
  16. Patrick Wong
    18,210
    6,514
    Other Prius owners have seen that message. Usually that is a false warning caused by a failing 12V battery.
  17. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Now I have change the 12v battery it work normal but I hope the problem can be fixed by that
    Anyways very thanks you all of friends here very appriceated
  18. bisco
    52,431
    pleasure.;)
  19. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    My question just Want to know 12v battery for
    Prius 2004 have 2 kind is one have battery water and
    No water . Beacused after I changes it from original
    Battery it have the small hole on the top and it not. The
    Same size . Please help clearify for me pls
  20. bisco
    52,431
    not sure what you have for batteries there. without more info, i would go with the dealer spec. is there a vent tube on both?
