Problem dash is completely dead and Ignition switch no lights
Discussion in 'Gen 2 Prius Technical Discussion' started by Tom600x, Nov 15, 2020.
  1. Tom600x
    Tom600x New Member
    Hershey, PA
    I have a 2009 Toyota Prius problem is the car will not start up and the dash is completely out, this occurred after I unplugged and plugged in the aux battery when I was clearing a previous code. The only thing that lights up on the dash are the hazard lights and the door open indicator. Also if the key fob is not in or near the car when pressing the ignition (on switch) it will display the missing key indicator so this tells me that the on switch is doing something. I also tried each keyfob near and in the slot.
    I have had a bad or weak aux battery in the past and this is not the same. The aux battery is charged and I am getting +12 volts at the fuse panel. I checked the AM2 fuse and that also has power as well as the fusible link. I also checked power at the fuses under the drivers side and the Gauge fuse has power. I checked I believe all fuses for continuity, most in and out of the car.
    I have the Toyota tech software but can not get it or another code reader to read any thing.
    I have also unplugged and plugged in the main battery and aux battery after letting it unplugged for a few days.
    The key fobs seem to work since they do open the doors and the lights flash.
    The ignition swtich / on button and dash do not light up at all no circle of green or orange, nothing.
    Before the dash issue I was able to read codes with the toyota software and another code reader.
    Any help is appreciated I tried a lot of information on this forum and elsewhere. I do not believe it is the same as other dash issues since others say their car works even thou the dash is out.
    Thanks for any help on this.
  2. Tom600x
    Tom600x New Member
    Hershey, PA
    I also pulled the DOME fuse and checked that and it was good.
  3. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    Besides the checks you did on the positive side I would check the ground starting with the ground strap. If you use your voltmeter with negative probe on 12v negative pole and the positive probe on the chassis do you get any voltage? What about between engine block and chassis?
    Do you hear the brake actuator when you open your door? Test also voltage between actuator ground and chassis. Any voltage?
    Just to make sure I would connect a jumper cable between the negative battery post and the engine or chassis to create additional grounding ( reduce resistance) and try if dash lights and modules work.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Don’t bother measuring anything at the battery.
    It only matters what the voltage is at the front jump point. That where the car sees the 12 volts. Measuring at the front jump point checks 8 battery connections and a long heavy duty cable before it hits the fuse box
    If voltage there is bad then you can go into full search and destroy on the battery in the hatch.
    kenoarto likes this.
  5. Tom600x
    Tom600x New Member
    Hershey, PA
    Thanks for the reply the voltage is good at the fuse box, front jump point + after the fusible link.
  6. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    The next step would be to then check all the fuses with an ohmmeter if you didn't do that when you did it the first time.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I sense that there might be more to this story. What code were you clearing when this saga began? Did you perhaps leave something unplugged while troubleshooting that code?
  8. Tom600x
    Tom600x New Member
    Hershey, PA
    I was getting the plock error message but that was not related to the normal aux battery issues. My daughter ran over a curb which pushed the transmission back some and busted up the bottom motor mount and crushed the oil pan. The connector on the shift control actuator was crushed. I replaced the shift control actuator and rewired the plug from other sources in the car since I could not easily get to it. The car then started and ran on jack stands but I believe since the wheels were all up on the stands the plock message came back on, I went to reset it with disconnecting the aux battery and then the dash went black, before that the car was running even the gas motor and front wheels spinning.
  9. DAM0
    DAM0 Junior Member
    26
    New South Wales, Australia
    I have the exact same issue. Happened to me this morning whilst driving at about 60kmh, everything in the car just died, no assisted steering or brakes, dash went totally black, etc. Now key is unresponsive, power button does nothing, all I can do is lock/unlock it with the key fob.
    Did you end up working it out?
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Your Inverter cooling water pump has probably burned up, blowing the AM2 fuse in the underhood fusebox. fairly common failure in the Gen 2. Remove the pump from the electrical circuit by unplugging it at the connector shown in the photo, then replace the 15 amp fuse. Drive carefully. Get pump replaced asap.
    ydpplqbd and DAM0 like this.
  11. Tom600x
    Tom600x New Member
    Hershey, PA
    I am not sure if this is my issue but I will try to disconnect the plug, my AM2 fuse is not blown and has 12v+ power as well.
    My dash and power button led has no lights.
  12. DAM0
    DAM0 Junior Member
    26
    It was my AM2 fuse dead, unplugged WP and seems to be working, however I still cant move the car or get it into "Ready" mode.
    I've seen other members that have a dead WP and were still able to drive their car?
  13. John Tyler
    John Tyler New Member
    North Carolina
    I had this problem, too. I would enter the car....hit the power button with my fob in my pocket - as normal, and the dash lights were all blank....a black screen. I would open the drivers door and slam it...snd somehow, the power button engaged, but my clock would always have to be reset and my radio stations had to be reprogrammed. I had replaced the 12 volt battery a month earlier, so it could not have been the battery....I checked the terminals on the battery figuring I had a rusty ground and needed to clean that up or a loose terminal. It had to be a battery problem! I pulled the red cap off the plus after seeing that the ground wire was secure...and the post it was attached to on the battery, When IK lifted the red cap, the terminal came off the post with the cap! So, it turned out that the new battery had a thinner post than the Prius battery and the lock -in 10 mm nut would tighten...but I could still wiggle the terminal. So, I loosened the terminal nut and got a small stainless screw and screwed it in between the post and terminal at the junction of the tightening nut and post.....screwed it in to take up that slack and tightened the post nut securely. This time...the positive terminal was tight and secure...reset the clock reprogrammed the radio stations....no problems since. JT
  14. andrew butterworth
    andrew butterworth New Member
    stockport
    ----UK----
    I have same problem no ignition no dash just central locking brake lights and hazards checked every fuse am2 fuse good with power to it battery is good fully charged power to under bonnet fuse box checked big aluminium fuse in fuse box good but nothing been trying for days
  15. andrew butterworth
    stockport
    ----UK----
    I have same problem did u fix
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,013
    NJ-USA
    Does the clock turn on when you push the power button? What you describe COULD be the result of a bad capacitor in the Combination Meter (speedometer - dash cluster) assembly. There's a sticky thread near the top of the Gen2 Care & Maintenance forum - I think it's the 4th one down.
  17. andrew butterworth
    stockport
    ----UK----
    The power button does nothing at all not a thing no dash no square centre display am2 fuse perfect every fuse good perfect battery good power to jump point under bonnet brake lights work lights work hazards work nothing through ignition no live at several fuses fuse bpx drivers side rhd car uk.it i give live feed to certain fuses dash lights up but cant get in neutral or power button not lit up.if i give power to cigarette lighter the centre square display lights up all working but no power to on switch
  18. jerrymildred
    11,517
    14,167
    Tampa, FL
    Did you check the fuses under the instrument panel? In our 2007, fuse #s 14 & 22 power the hybrid system. There could be other possibilities in there.
  19. andrew butterworth
    stockport
    ----UK----
    Hi did u ever find the problem
  20. Jason85
    Jason85 New Member
    Myrtle beach
    I am having a similar problem. Did you ever find a solution?
