Problem message keeps coming up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Thomas Wesley Heard, Jul 11, 2020.
  1. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Please, no.
    I agree too. At the very least (if it has to be in there) the glossary should say it is a silly acronym and the correct term is the Master Warning Light (MWL).
    VFerdman likes this.
  2. Thomas Wesley Heard
    Thomas Wesley Heard Junior Member
    37
    Halifax County VA
    Replaced the inverter coolant water pump and still getting the same code. Any ideas?
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Were you able to purge/bleed all of the air from the coolant loop?
  4. Thomas Wesley Heard
    37
    Halifax County VA
    Ive tried bleeding it but I can't get the coolant flowing from the bottom bottom to the top (sorry don't know the mechanical names).
  5. dolj
    dolj Senior Member
    8,646
    4,398
    Your non-mechanical names are not helpful, maybe a photo?.
    So, are you attaching a length of 1/4" vinyl tubing between the bleed valve and the reservoir and then opening the bleed valve? Do this while the pump is running.
    SFO likes this.
