1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Problem plugging in dead iPhone to USB port
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by davidbw, Apr 19, 2012.
  1. davidbw
    davidbw Member
    110
    29
    In front of my computer
    Is there a secret to not having the radio switch to the iPhone when plugging the iPhone in? I usually start the day with the radio set to an AM station. It takes a few minutes for the Prius to recognize the iPhone plugged into the USB port, but when it does recognize it, it immediately starts playing iPhone music. Is there away for the iPhone to connect for Entune, but not switch the audio from AM to iPod?
  2. Priuskat
    Priuskat Junior Member
    36
    Orange County, CA
    I'm looking for the secret to make the car speakers to link to my Iphone. It worked once or twice. . . but I have no idea why? I've tried shutting car down, disconnecting phone, etc. no luck . . . so I listen to radio w/ commercials . . . then radio keeps jumping from HD to regular.
  3. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    David, if there is a way, I haven't found it. My own 2011 IV does it too.
    Is there a way to do this, does anyone know? I have taken to just resurrecting my Spring charger with the USP port embedded into the top of it. That solved my problem!
  4. DianneWhitmire
    4,062
    1,123
    64
    Laguna Niguel, CA
    If I was your selling dealer, I'm sorry this isn't resolved. I'm all yours! Let me help!
    If I was NOT, then you do have a dealership & a salesperson you can go to for help or a tech person in their service department. Their customer relations manager can also step in and assist.
    If you have a deep abyss between them and you, for some reason, I may be able to help (or my asst. Nathan) - we are pretty good at this!
  5. Priuskat
    36
    Orange County, CA
    Thank you . . . .you were not my selling dealer - my mistake which cost me :(
    I will take to dealer . . . hoping that it would me an easy fix (it worked 2x). If not, when I go to the next LA Galaxy Game, I'll see if you or Nathan are available.
  6. TruSound
    TruSound Member
    246
    32
    The 818
    I've switched over to the 12 volt plug to charge the phone, like you my radio bugged out when I plug into the usb plug...
  7. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    I don't know if this will help, but I had a similar problem where I couldn't get my iPhone to work properly. The solution is to make sure you have an Apple or Belkin cable. It has something to do with the data transfer rates (service bulletin). The other thing to do is to reset your iphone:
    1. Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time.
    2. Hold them both until you see the screen go black. In some cases, you may need to keep holding them even after the red power off slider appears. If it does, just keep holding it.
    3. Wait until the white Apple logo appears.
    4. When this happens, you can let go - the iPhone is rebooting.
    If you have Sat or Radio selected when you turn your car off, wouldn't it automatically go back on restart? I don't know, because I always listen to podcasts when I am driving, so I want it to go to the iPhone. Although, sometimes it won't switch to the car speakers and I have to either re-plug in or reset the iPhone, kind of frustrating.
  8. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I have also noticed a problem with the Bluetooth audio not always working. I'll select Bluetooth audio from the Audio screen, get the spinning disk as it attempts to start up, and it just sits there. It seems to be related have switched back and forth between using the Bluetooth connection and the USB port for music in some previous session.
    To get bluetooth audio playback to work again, I've had to go into the Music app on the iPhone and reset the audio connection it's using. To do this, you go to the Now Playing part of the app. Next to the play button will be an icon that looks a bit like an envelope. Tapping on it brings up the audio source menu. Select the Car Audio, or Advanced Media, or whatever the car shows up as. Doing this should reenable Bluetooth audio playback and control.
    Hopefully this will help you if you've been trying to use Bluetooth audio. This should be a bit easier than having to reboot the phone.
Loading...
