Problem: Prius is saying handbrake is on while it isn't
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2007priuslol, Apr 16, 2021.
  1. 2007priuslol
    2007priuslol New Member
    UK
    After draining the brake fluid on my 2007 Toyota Prius and putting new brake fluid, the car keeps beeping without stopping until I turn off the car. I have the VSC light on the dash, ABS and the (!) light which I don't know what it means. The car also says the handbrake is on when I turn it off.
    49,446
    maybe needs to be bled
    jerrymildred likes this.
  3. ChapmanF
    15,569
    Leeches for the win!
    mr_guy_mann and jerrymildred like this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    IF......you don't know what ABS is, you have no business doing any work on the brake system in a car.
    Part of replacing the fluid is "bleeding" the air out of the system.
    With an ABS system, that can be a fairly complicated proceedure.
    NOW you need to see a shop to finish the process correctly.
    P.S. Are you sure you used the right type of brake fluid ?
    How do you intend to dispose of the old fluid that you took out ??
    #4 sam spade 2, Apr 17, 2021
    2007priuslol likes this.
  5. ChapmanF
    15,569
    By feeding it to the leeches of course.
