Problem: red triangle & red power light when powering on car
Discussion in 'Gen 2 Prius Main Forum' started by jmann, Mar 20, 2010.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Good point. This is why almost any battery that physically fits will work, I keep an old RAV 4 battery on a float charger (wet cell) as my next aux bat. After being installed the cars charge system will continue to charge at something comparable to my float charge. I also keep a small gel (7.5V) for emergencys. If you want to repeat the same problems again in 3-4 years by all means get the OEM Battery. Incidently, both of my substitute batterys work fine, I installed them and tested them for a couple of weeks. :cheer2:
  2. richard schumacher
    7,686
    1,068
    United States
    Certainly any vented 12V battery will work. The fun is in finding one that fits in the available space and in making the Toyota cables fit to its posts.
  3. andyprius
    2,212
    188
    True, I filed down one of the post on the wet cell and drilled a small hole for the vent tube above the electrolyte line. But you are right, finding the right physical size, and approximating 30AH is the problem. I think a lot of Motorcycle batteries would work also.
    :rockon:
