Problem with CV aXLE replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HAWGMAN, Jan 27, 2023.
  1. HAWGMAN
    HAWGMAN Junior Member
    17
    Murray, KY
    I replaced the driver side CV axle on my 2006 prius. However after completion the car doesnt move when I put in drive and rev the engine the traction control light comes on. I noticed in a thread about cv axle replacement Patrick Wong recommended disconnecting the battery before starting so "you dont induce skid control ecu DTC" so how do I correct this condition?(the battery was connected while I repaired the axle didnt see his post until afterward) It was driving perfectly other than the bad axle before hand no DTC codes.
    #1 HAWGMAN, Jan 27, 2023
  2. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Try disconnecting the 12v battery for 30 seconds now and see if the problem clears. Otherwise you will need to use a Prius aware ODB2 test environment to clear the code.
    JeffD
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Other things to consider (I do not know for certain if these would cause your symptoms) Are you confident the speed sensor for that wheel is undamaged and plugged in? Is it still peeking through the hole in the dust shield to view the tone ring?
  4. HAWGMAN
    17
    Murray, KY
    I didnt disconnect it, but I will check it. thanks for the tip
  5. HAWGMAN
    17
    Murray, KY
    Thanks Jeff, I did try unplugging the battery for a day while I recharged the 12v to make sure it was up. I till try to get tech stream up again. havent had it going in a long time. I have a BT dongle that worked before.
  6. HAWGMAN
    17
    Murray, KY
    Well you were right I finally got good weather and I checked and yes the speed sensor the hole in the dust cover was covered I fixed that and reset the battery. But still getting the same thing.
  7. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Are you sure the axle is good, and all the splines lined up? Do you feel anything when putting it into D? Sounds more mechanical than electrical.
