Problem with display 2008 Prius. Help!
Discussion in 'Newbie Forum' started by JenWeb, Oct 22, 2017.
  1. JenWeb
    JenWeb New Member
    Does anyone know what is causing this in a 2008 Toyota Prius? It started out doing this only in navigation, but now only the climate works normally.
    22555089_1629213023768533_646481224749916276_n.jpg 22555150_1629213010435201_8660849794698671038_n.jpg 22552565_1629213017101867_273330088783359400_n.jpg
  2. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    Welcome. Interesting but unfortunate issue you have there. My first thought would be a bad solder connection somewhere in the display. But if it started just in Navigation and then spread from there, then that's pretty hard to sort out.
    Hopefully, someone here has more info on how much of the display is generated within the MFD and what is fed to it. Judging by the price of a new one, I'd guess it's a pretty smart display. It's pretty easy to replace (there are several videos) and you should be able to pick up a used one if that's actually the problem. The patterns actually remind me of a failed GPU in a computer.
    49,513
    welcome!
    check with luscious garage.
    jerrymildred likes this.
